Filter Converter - HVAC - DIY Chatroom Home Improvement Forum
Old 02-21-2013, 09:42 AM   #1
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Filter converter
Does anybody make a converter or know how to make one to switch from 20x25x4 to 20x20(25?)x1 filters? These things are huge and expensive.
--Chris
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
Old 02-21-2013, 10:08 AM   #2
Houston204's Avatar
Rewards Points: 556
Wow, I went the other route to use a 4 inch mechanical filter so it wouldn't require replacement as often.
I have seen a long spring, like those used in old screen doors, used to hold the filter to the furnace side of the mechanical filter rack.
It looked like the rack had a spot to catch the spring.
I don't remember if it was a Carrier or Honeywell filter rack.
A 1 inch pleated filter might reduced your airflow.
I recommend checking the heat rise across the furnace.
Houston204 is offline   Reply With Quote
Old 02-21-2013, 11:58 AM   #3
Rewards Points: 42
I would do the math before changing it. I can get 2 years out of my 20x25x5 filter. The filter costs $20.00 purchased online.
djlandkpl is offline   Reply With Quote
Old 02-21-2013, 01:58 PM   #4
AKA HVACTECHFW
Rewards Points: 1,208
it may be expensive, but you don't need to replace it every month!
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 02-21-2013, 02:52 PM   #5
Still going...
ChrisDIY's Avatar
Rewards Points: 508
I guess I have a combination issue. The return is undersized so the unit only works right, if door to closet the unit is in, is left open. Original owner cut hole in second floor/closet ceiling, size of return duct 8x24, I added 8x12 through wall above door so I am still 152 sq. in. short. I guess if you use size of unit to determine the proper size. 20 x 22.
The other problem is the unit is too large for the closet so getting the 20x25x4 in and out is way too hard! The other reason I want to drop to 1"
--Chris the DIY Guy
Inline water filter for built-in fridge (water supply line on top) Druidia Appliances 5 03-10-2012 12:05 AM
Black material in water filter Sartrean Plumbing 4 03-09-2012 05:31 PM
Inground pool and filter...HELP! Blpavlovich Building & Construction 2 06-09-2011 05:49 PM
furnace filter fit?? Doug7852 HVAC 4 04-01-2011 10:45 AM
Bypass Humidifier goes before or after air filter? key1cc HVAC 9 12-30-2008 09:12 AM
