Filter In Concord 80 Plus Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 11-11-2006, 11:59 PM   #1
filter in concord 80 plus furnace
Maybe this is a just dummay question to ask. I recently purchased an old house which has condord 80 plus furnace installed. While I was going to replace the filter for it, I was not able to find where the old filter was placed. Does anyone have some idea on where the filter is located? Many thanks,
hyyx632 is offline   Reply With Quote
Old 11-12-2006, 07:24 AM   #2
World famous jerk.
The filter location is less a function of the model of furnace, and more of a function of how it was installed (the installer's style or perhaps an over-riding physical constraint).
Popular locations are in a "filter rack" right next to the furnace in the return air plenum (this may have a little skinny flip cover on it), right inside the furnace's bottom panel in the R/A section, or in a "filter grill" somewhere in the house. This is a large return air register with hinges and latches. In a mobile home style furnace (and in homes with heating systems set up similarly to a mobile home), the furnace has no return ductwork. The furnace may be installed in a small centrally located closet, and the filter is on the back of a louver in that closet door.
mdshunk is offline   Reply With Quote
Old 12-11-2008, 07:57 PM   #3
Question
not a dumb question at all!!! same scenerio. same furnace. Ive looked high and low, had three other guys look too (in doubt of my own observation). no filter. Ive been told that this type of furnace was originally used in mobile homes, but not this furnace. should i alter the cold air return duct, to put a filter in it? pretty sure there's no filter here, dust is starting to accumulate.
any suggestions??? .... any one???
tdogg is offline   Reply With Quote
Old 12-11-2008, 08:46 PM   #4
look inside the blower chamber.
hvaclover is offline   Reply With Quote
Old 12-12-2008, 10:06 PM   #5
still no luck
cant see any thing there either
Old 12-12-2008, 10:21 PM   #6
Check to see if you have a filter back return grille (return grille that is hinged) If not check inside the blower for what looks like a wire hanger -- this will allow for a filter not to get pulled in to the blower housing
NYCtinman is offline   Reply With Quote
anyone ever hear of concord furnace? THEBIGPUNN HVAC 17 01-06-2016 04:17 PM
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Furnace filter ? ej72 HVAC 6 07-09-2009 08:30 AM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 05:00 PM
furnace filter dmike25 HVAC 1 12-25-2006 12:28 AM
