Filling Gap Between Furnace Exhaust Vent Pipe And Ceiling - HVAC - DIY Chatroom Home Improvement Forum
Old 10-26-2010, 05:16 PM   #1
Filling gap between furnace exhaust vent pipe and ceiling
There are significant gap/clearance that I'd like to fill between my furnace exhaust vent pipe and ceiling. What should I use to fill/seal the gap so it won't catch fire and still preventing cold air to go through?
tkfd3s is offline   Reply With Quote
Old 10-26-2010, 05:42 PM   #2
High temp silicone, metal patch with the correct sized hole cut out, storm collar with RTV. More then one way to skin a cat.
Old 10-26-2010, 05:56 PM   #3
A Vent Fast pipe hanger/firestop for your pipe size would work best.
SKIP4661 is offline   Reply With Quote
Old 10-26-2010, 06:43 PM   #4
Rewards Points: 392
I actually picked up a firestop for Bvent at home depot. You need 1" clearance between the Bvent pipe and the drywall/studs.
-Jeff
zootjeff is offline   Reply With Quote
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 08:31 AM
Run vent pipe in soffit along with duct trunk acerunner Plumbing 1 09-28-2010 08:06 PM
Leak found - need advice (Vent pipe) krooser78 Plumbing 0 03-29-2010 02:49 PM
Condensation From Exhaust Pipe Chetter HVAC 6 11-30-2008 04:04 PM
framing conundrum: 2" PVC vent pipe going horizontal through 2x4 studs amakarevic Building & Construction 18 01-19-2008 06:47 PM
