Fieldpiece Or Subco? - HVAC - DIY Chatroom Home Improvement Forum
Old 08-08-2011, 07:25 PM   #1
I'm Your Huckleberry
Rewards Points: 2,270
Fieldpiece or Subco?
Digital psyhcrometer? I can get the FP for $126 (discounted price for the working hvac man, $166 normal) and the Subco for $177.
Any of you had either? Experiences?
I know the FP does target sh, wet and dry bulb and rh. Not sure what all the Subco does, I haven't actually seen it up close and personal like I did the FP today, but I'm pretty certain it does the same.
Buying one tomorrow.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 08-08-2011, 07:31 PM   #2
JJboy's Avatar
I received Fieldpiece SRH2 today.
2 K-type thermocouple
Measures RH%, Dew point, Wet bulb, Dry point.
Also TSH - Target Superheat
TEET - Traget Evaporator Exit Temp.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
The Following User Says Thank You to JJboy For This Useful Post:
Doc Holliday (08-08-2011)
Old 08-08-2011, 07:37 PM   #3
That's the same one. I recall seeing that "TEET" word on the cover but didn't know what it meant so thanks.
Have you used it yet, can you measure it's accuracy?
Old 08-08-2011, 07:46 PM   #4
JJboy's Avatar
Not yet. Let me compare with Extech RH350
I think TEET is delta T
"The TEET ( also known as Target temp Split) calculation allows you to determine if you have airflow problems in your evaporator coil."
Old 08-08-2011, 08:51 PM   #5
The old fashioned way is a wet shoestring. Insert the k probe into the shoestring and wave it around for a few seconds, like a sling psychrometer. All it costs is $6.
Yes im a cheap bastard.
Master of Cold is offline   Reply With Quote
Old 08-09-2011, 04:56 AM   #6
An old Tradesmen
Rewards Points: 7,372
Digital i a bit better, since you can get a more accurate measurement of the wetbulb temp in the return right at the unit.
The wet shoestring method, in order to be accurate, needs to be moved around at roughly 1000FPM. Thats a bit hard to do.
I'v e done it a few times, when my batteries were dead or too weak in my digital, and I didn't have my sling with me.
Old 08-09-2011, 11:16 PM   #7
Got it.
Old 08-10-2011, 12:15 AM   #8
Old 08-10-2011, 01:54 AM   #9
JJboy's Avatar
Good stuff
Doc Holliday (08-10-2011)
Old 08-10-2011, 12:54 PM   #10
JJboy's Avatar
Doc, have you tested TSH with TC and TSH with NTC?
Target SH values ​​are very different in these two methods.
Old 08-10-2011, 04:55 PM   #11
You know, beer can cold is a lot easier...
Old 08-10-2011, 05:22 PM   #12
JJboy's Avatar
I am not getting the same result for Target Superheat (TSH) when I'm using the method using thermocouple K-type ATWB1 - ATA1 and with NTC caged sensors. The results are almost twice each other.
Old 08-10-2011, 05:36 PM   #13
Are you waiting for the wet bulb thermocouple to hit it's lowest point JJ?
Old 08-10-2011, 05:37 PM   #14
Hvac Pro
yuri's Avatar
Rewards Points: 2,274
I agree. That way we don't have to call the NTC or ABC or FBI or whoever
Old 08-10-2011, 05:48 PM   #15
JJboy's Avatar
No, I wonder why the two target superheat are different when using different sensors
fieldpiece H36 purchase wetbar HVAC 3 07-20-2010 07:08 PM
