FHW Baseboard Pipe Knocking - HVAC - DIY Chatroom Home Improvement Forum
Old 01-20-2013, 09:07 AM   #1
Rewards Points: 350
I am having this issue on my second floor where the bedrooms are....
The heat piping run is entirely on this floor (save for the feed up and return back to boiler). So each register has the pipe that comes up from the floor, feeds the register, then goes back down into the floor to the next register.
One room is just very noisy, especially when it's cold and it's 2AM, lol. The knocking starts gently, then gets faster and louder and eventually stops. I do not hear anything until the next boiler run. If it was only expansion, wouldn't I hear something as the ppe cools? I have widened up the holes where they come through the floor, but I am thinking it is either under the floorboards, or some sort of pressure bleed thing...
Any ideas?
Pardon any typos, my IPad has a mind of it's own for spelling corrections!
dougp23 is offline   Reply With Quote
Old 01-20-2013, 09:56 AM   #2
An old Tradesmen
Rewards Points: 7,788
Turn stat up. Go to room and trace out area noise is worse at. Proceed from there.
Old 01-20-2013, 11:52 AM   #3
how
Rewards Points: 1,104
Angled pipe straps can often make noice in one direction of expansion but not the return (or vise versa).
how is offline   Reply With Quote
Old 01-20-2013, 02:38 PM   #4
Roofmaster
Rewards Points: 2,210
It has been my understanding that this is caused by improper slope in the pipe which traps air above the hot water. I would say to check the grade on your pipes.
Old 01-20-2013, 03:43 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,612
Nope,... Not necessarily,... The pipes heat up, 'n expand, Quickly, but cool quite slowly...
Old 01-20-2013, 06:54 PM   #6
Rewards Points: 350
Thanks everyone! I will have to open up the floor and see why the pipe is making that much noise. If you are sitting in the room directly below, you can hear it knocking quite loudly as well, so I imagine it must be an expansion issue.
Old 01-21-2013, 03:29 AM   #7
REP
What you are discribing is a STEAM system problem and does not apply to this HOT WATER system
REP is offline   Reply With Quote
The Following User Says Thank You to REP For This Useful Post:
jagans (01-21-2013)
Shortening a baseboard radiator - very thin pipe wombosi Plumbing 7 11-12-2012 07:16 AM
Question about copper pipe agroom Plumbing 3 10-27-2011 02:18 PM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 09:23 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
Backpitched Cast Iron Pipe in Basement....uggh.. apunaha23 Plumbing 5 02-02-2011 01:42 AM
