FHW / Baseboard Heat Takes Forever - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-19-2013, 07:06 PM   #16
biggles's Avatar
if you had high winds with that night time temp it will seem the heat isn't working along the wall. heat always goes to the colder spot.if the 160/190 is up on that first bend on the zone run the pump has to be working and the cold wall is pulling the heat from the baseboard 20f 30f makes a difference when heating a stat on a zone.
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Electric baseboard VS Heat pump Mattme123 HVAC 20 09-21-2012 08:41 PM
wainscot above baseboard hot water heat scroff Remodeling 7 09-11-2012 11:57 AM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
Baseboard Heat 80% Rule Question bltglt507 Electrical 1 11-06-2009 11:17 AM
