FHP Unit May Have Bad Pressure Switch - HVAC - DIY Chatroom Home Improvement Forum
Old 08-26-2016, 12:44 PM   #1
Rewards Points: 6
FHP unit may have bad pressure switch
re: Help - finding parts for older FHP unit
Recently our buildings well pump was shut down for servicing and we failed to promptly turn our unit off. Came inside and unit was still going strong so I shut it down in the knick of time w no problems.
Then my a/c bud said I should change the hi-pressure switch, (maybe stuck closed), for me to order it and he'll replace free of charge, (just gotta take him fishing).
Question: For my FHP unit, (FL Heat Pump), where is a good source for a replacement made by Bosch, part #8733-908-068? (Oem= fhp# 640-004). Thanks in advance, any & all positive suggestions will be appreciated!
(above repl-part# provided by Fhp/ open-close = 380/300)
FHP unit may have bad pressure switch-fhp-switch1.jpg   FHP unit may have bad pressure switch-fhp-2.jpg
mrsnapper is offline   Reply With Quote
Old 08-26-2016, 01:32 PM   #2
Rewards Points: 3,656
Re: FHP unit may have bad pressure switch
Is the switch actually faulty? I'd want to know before I ordered anything.
roughneck is offline   Reply With Quote
Old 08-26-2016, 02:26 PM   #3
Rewards Points: 6
I'm 90% certain that it is since the unit kept running while the pump was down,
and since I'll have a "free" installation, just have to buy the parts, I think it's
worth the risk. Besides, the unit has to be about 15+ yrs old.
What is it, about a $25-$35 part?
Also, I had a tech here once said that someone had disconnected/bypassed it.
He wired it back in.
So just playing it safe, trying to keep from having to replace entire unit.
Old 08-26-2016, 02:34 PM   #4
Might want to have the unit checked out, as running with no heat transfer medium can cause major damage.
That part is available off of most any supply house shelf.
Old 08-26-2016, 04:17 PM   #5
Rewards Points: 6
this has been the challenge! its an older unit and I don't want to throw a cheap replacement in there. My buddy is way to busy for this. I wrongly assumed this wd go with a lot less resistance as I think we're talking about a $35 part. I was looking to stick with the oem Bosch part - but the mfr stated they only have 2 distributors locally.
can you recommend a good online parts source?
Old 08-26-2016, 10:44 PM   #6
Rewards Points: 46
High pressure switch, 1/4" flare. (i like manual reset)
http://r.ebay.com/AJAXAV
With a swivel tee.
http://r.ebay.com/ylqwFs
Cheers!
supers05 is offline   Reply With Quote
Old 08-26-2016, 10:49 PM   #7
Rewards Points: 1,832
First thing I'd do is hook gauges up to the unit, make sure it has enough charge and then get the pressure once the high and low side stabilize.
Jump-start is offline   Reply With Quote
Trane XR90 Induction fan issue & Pressure Switch VARider HVAC 8 02-28-2015 09:26 AM
Pressure switch stuck open? 2 areas im looking @ 1001miles HVAC 42 12-03-2012 04:51 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
Pressure Switch Problem? American Standard Pack Unit jaymel HVAC 4 10-20-2008 06:10 AM
