A Few Questions About Our Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 02-19-2008, 06:38 AM   #1
When is fishing season?
CowboyAndy's Avatar
A few questions about our furnace
Hi everyone, over the last few days I noticed our furnace is "shaking" or "vibrating"... if that makes sense? Basiclly, when it fires up, it kind of "rumbles" the whole floor. Also, is it normal for the blower to kick on for 30 sec or so THEN the burner fires up? It seems like it is blowing cool air before warm air.The furnace is only about 6 years old. I am not sure of the model and size, but I can check when I get home.
CowboyAndy is offline   Reply With Quote
Old 02-19-2008, 10:36 AM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
Could it be that it's not the blower but a power vent that is turning on before the furnace fires?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 02-20-2008, 09:18 AM   #3
CowboyAndy's Avatar
I am not sure what that means, but I can say for sure cold air starts coming out for about 30 sec, then you can hear the burner fire up and it almost instantly turns warm/hot.
Also, any thoughts on the rumbling with it fires up?
Old 02-21-2008, 09:53 AM   #4
Charley B's Avatar
What that means is you probally have a small combustion air blower in side the furnace cabinet that starts before the burner fires but that does not sound to me that is your problem. The blower motor is not suppose to energize before the burner fires and this is controlled by either an electrical/temp switch or a electronic control board that times the blower on. Control boards are not adjustable and would need replacing if not functioning properly temp switches are adjustable would need to know what you have.
As for the rumbling can be many things that cause this such as flame roll out, delayed ignition, blower noise out of balance due to lint build up and the list goes on and on.
Charley B is offline   Reply With Quote
Old 02-21-2008, 09:56 AM   #5
CowboyAndy's Avatar
So, where should I start trouble shooting?
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
Old 02-21-2008, 10:24 AM   #6
Charley B's Avatar
Don't know what type controls you have a Pic would be nice but you need to remove the cover on the front of the burner chamber and watch the burner come on. Do not remove the cover on the blower chamber as there is a switch that prevents the gas valve from opening if that cover is removed.
Old 02-21-2008, 10:44 AM   #7
CowboyAndy's Avatar
Okay, I will take some pics later tonight or tomorrow.
MY HOUSE OWNS ME!
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Furnace venting questions Mastiff HVAC 9 12-05-2012 05:51 PM
Oil Furnace Questions mudpaws HVAC 8 12-29-2010 02:29 PM
Questions about American Standard Products bhpizza HVAC 5 06-12-2007 08:36 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 05:00 PM
