A Few Questions. - HVAC - DIY Chatroom Home Improvement Forum
Old 09-09-2011, 04:28 PM   #1
I'm Your Huckleberry
Rewards Points: 2,270
A few questions.
1.) Can refrigerant go flat in a system, say if a system has been off for six months? Can it sit idle for that period of time and then once started show low pressures even once stabilized?
2.) What's the minimum voltage required to start and run an evaporator 208/240 volt blower motor? I came across a furr down that had 122 at each leg but across leg to leg only had 210.
I checked continuity throughout wires from motor and it showed coninuity and I checked the run cap as well, all was good but the motor would not spin. Low voltage was present as well.
This is the furr down in question.
And this is the condenser which was hanging on the outside closet wall of the high rise condo attached to said furrdown, both on one double 40 pole breaker.
The condenser would come on, both compressor and fan, but the inside unit would not.
Doc Holliday is offline   Reply With Quote
Old 09-09-2011, 05:27 PM   #2
1-Refrigerant escapes from a leak if the system is on or not.
2-Can't remember exactly but it's in the mid 180's .
Bad motor and a leak repair adds up to more then that thing is worth. Still the customers choice on what they want to do though.
The Following User Says Thank You to Marty S. For This Useful Post:
Doc Holliday (09-09-2011)
Old 09-09-2011, 05:59 PM   #3
JJboy's Avatar
Refrigerant moves from high pressure to low pressure. The pressure inside the linesets will be high than outside. So It's gonna leak slowly.
Look like the voltage is ok.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
The Following User Says Thank You to JJboy For This Useful Post:
Old 09-09-2011, 06:02 PM   #4
Make sure the transformer is set to 208 not 230. There's usually a tap by the leads.
It leaks faster proportionally at higher pressures (like summer temp=pressure)
But time added in will mean ur gonna be frozen at start up in spring :$
Dr.HVAC is offline   Reply With Quote
Old 09-09-2011, 06:03 PM   #5
I was thinking something along the lines of the oils seperating and sitting on the bottom of the coils. Possible, like stacking?
Old 09-09-2011, 06:06 PM   #6
It is a 240 step down transformer and in all honesty I think the motor is bad. I said I tested continuity and I did but between the fan wire to the run cap and the run wire from motor there was nothing. That's it, isn't it?
There was continuity between the run and the common from the motor.
Old 09-09-2011, 06:08 PM   #7
Which leads and were they disconnected? A grounded motor would have thrown the breaker
Old 09-09-2011, 06:13 PM   #8
My boss said that as well, saying there's a minimum votage to crank the motor over and 210 volts should do it and I thought as much as I've been down this road before BUT... don't tell anyone, I just wanted to go home so I told her to get an electrician and if that doesn't fix it then I'll be back to replace the motor.
She said she never uses the system as she's rarely ever and she does have another system which works perfectly (one system for one side of the loft and one system for the other side, split left and right), but I'll be back to replace the motor.
I had a strong hunch it wasn't the voltage, I was just kind of hoping.
Also, her 5 microfarad run cap which was plus 10% minus 5% was reading at 4.1, well below the -5% so I installed a new one in the hopes that might work but still nothing.
Old 09-09-2011, 06:15 PM   #9
JJboy's Avatar
remove motor wires, cap and motor will act like inductor.....
Old 09-09-2011, 06:22 PM   #10
Not grounded, open windings. The hot common wire from the breaker in the furr down runs to one side of the fan run cap. From there a common wire from the motor itself is also connected to the cap so now two wires on one side of the cap. There is also a black wire which I want to say comes from the fan delay relay to that common side of the cap. Then there is the fan wire from motor itself that connects to the other side of the run cap.
Between that other single wire on the other side of the cap and either the run (black speed tap wire) or common from motor there was no continuity.
Between the yellow common and the black "run", both from the motor, there is continuity.
There should be continuity between any and all wires coming from the blower motor, showing windings in tact.
Old 09-09-2011, 06:23 PM   #11
Could you explain further, please?.
Old 09-09-2011, 06:23 PM   #12
I mean the inductor part. I did remove all wires and test between them.
Old 09-09-2011, 06:35 PM   #13
You're talking about my nine volt battery in my meter creating the magnetic field in the copper windings, right JJboy?
Old 09-09-2011, 06:36 PM   #14
JJboy's Avatar
This is the proper way to test continuity.
When testing continuity that has other components in series or parallel .... It creates effects such as resistance, capacitance or inductance
Old 09-09-2011, 06:37 PM   #15
Yup, I even went to school for this. Doh!
http://www.tabtronics.com/TECHNOLOGY...9/Default.aspx
Help How to Wire Bathroom "Fan Heater Light Night-light" unit, and questions Tryvidy Electrical 9 06-18-2012 03:37 PM
Basic (hopefully) electrical questions k2000lbs Electrical 10 04-27-2011 01:59 PM
Trying to update 60 year old basement/crawl... many issues & questions billyh Insulation 1 03-24-2011 01:07 PM
How thick should my thinset be? yummy mummy Tiling, ceramics, marble 20 09-28-2009 01:36 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 11:56 PM
