Faulty Boiler Gas Valve - HVAC - DIY Chatroom Home Improvement Forum
Old 01-31-2014, 05:40 AM   #1
I have just had a sevice done on my 6 year old Worcester Greenstar 24i System Gas Boiler and have been told the Gas Valve can not be adjusted to the minimum pressure required to allow the emission test to be done, and so I need a new gas valve fitted at a cost of 260. The boiler appears to be working fine otherwise.
Do I really need a new valve or is there another reason for this problem?
eribar is offline   Reply With Quote
Old 01-31-2014, 06:04 AM   #2
DIY staff
Rewards Points: 7,174
I moved this to 'heating' (HVAC) for you---a boiler man is on line so hopefully he will see this---
Old 01-31-2014, 08:12 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,440
Possibly the adjusting screw for the regulator is stripped/damaged/stuck so yes you need a new valve and it is important or it won't burn cleanly/properly or efficiently.
How to change a bad pressure relief valve maddog1 Plumbing 2 12-17-2012 01:46 PM
pressure relief valve is leaking on boiler wlmpdiycr HVAC 65 10-26-2011 06:00 PM
Fernice boiler gas control valve daveandjetty Appliances 1 11-22-2010 07:54 PM
