FAU Fan Won't Shut Off Unless Breaker Is Switched To Off - HVAC - DIY Chatroom Home Improvement Forum
Old 10-13-2012, 03:15 PM   #1
FAU fan won't shut off unless breaker is switched to off
i replaced my old stat with a honeywell rth111 series nonprogrammable and hooked up the wires as instructed. cool a/c worked fine, but when i switched it to heat for the first time, the fan came on and woouldnt go off unless the breaker was thrown. fan swithc on the stat is set to auto.
bunk is offline   Reply With Quote
Old 10-13-2012, 05:12 PM   #2
biggles's Avatar
on the subbase the G is GREEN stat wire and the W is the WHITE stat wire
Hot Tub GFCI Test Button Not Tripping Breaker a2zunknown Electrical 7 08-20-2012 08:49 AM
GFCI Breaker Tripping Spa Light eaposition Electrical 21 09-08-2010 10:57 PM
small voltage on circuit with breaker off jasonmechler Electrical 3 08-24-2009 09:52 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 09:59 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
