Fasco Motor Replacement/ Cross Reference - HVAC - DIY Chatroom Home Improvement Forum
Old 10-10-2011, 07:25 PM   #1
Fasco motor replacement/ cross reference
Does anyone know how to cross reference a motor? I have a Fasco Mod # 7855MVA-A11U. I need to find either a direct replacement or cross it to another brand. I'm in the Houston, Tx area so something local would be great. Thanks for your help
Paul33 is offline   Reply With Quote
Old 10-10-2011, 07:49 PM   #2
Houston204's Avatar
Rewards Points: 556
Are you sure about that number? The example does not look like that.
http://www.fasco.com/xref_list.asp
Houston204 is offline   Reply With Quote
Old 10-10-2011, 07:58 PM   #3
Yes, positive about the #...it's a 1/3 hp, dbl shaft motor for a rooftop RV A/C unit. Oddly enough, the link you posted I had already checked and it shows nothing for that #
Old 10-10-2011, 08:35 PM   #4
Houston204's Avatar
Rewards Points: 556
I have no experience with RV's. What is your voltage? Grainger or Johnstone may be able to match it if it isn't 12VDC.
Old 10-10-2011, 08:44 PM   #5
I found a link to one, but I have to "register" for the site and it doesn't even give a company location.
http://www.bestbuyheatingandaircondi...ory_Code=fasco
Old 10-10-2011, 10:26 PM   #6
see my comments on this recent post:
Will new induced draft blower work?
diyorpay is offline   Reply With Quote
electric motor cross reference markdcoco Electrical 29 09-17-2014 01:24 PM
Inducer motor; ID on Part: Carrier Part # HC21ZE123A - Cross reference help mtom01 HVAC 10 02-20-2011 06:43 PM
B & D battery cross reference CarolinaHawk Tools 0 12-28-2010 01:07 PM
removing joist cross bracing williemyers Building & Construction 1 08-11-2009 01:20 PM
HVAC Fan Motor Cross Reference markdcoco HVAC 3 06-17-2009 12:07 PM
