Fart Fan Piping - HVAC - DIY Chatroom Home Improvement Forum
Old 03-01-2012, 11:20 PM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Fart fan piping
I have 3 fart fans that are only vented into the attic, and I want to get them outside. The easiest solution for me is to run them through the attic and out the gable end of the building.
Does the maximum distance these vents can travel depend on the fan pushing them or is there a code requirement? If it's based on the fans, will the fan specifically tell me the distance, or is there some kind of formula based on CFM ?
Is it preferred to have them go out of the roof or out a side wall using a wall cap? (I'd personally not like to have to add 3 more roof penetrations if possible)
What about putting the exhaust down through a soffit? This is probably my last choice due to the fact that steam rises, and would probably make a huge mess out of the soffit material.
Journeyman Plumber
Old 03-01-2012, 11:26 PM   #2
Rewards Points: 1,010
You sure you want to do that? Keep in mind that venting your farts into the attic may be the only thing keeping squirrels, birds, raccoons, bats, rats, burglars, aliens, Pauly Shore, etc. out of your attic....
spaceman spif is offline   Reply With Quote
The Following User Says Thank You to spaceman spif For This Useful Post:
CplDevilDog (03-02-2012)
Old 03-01-2012, 11:30 PM   #3
Missouri Bound's Avatar
Do you want it your way or the right way?
Old 03-02-2012, 10:30 AM   #4
Doing it myself
Alan's Avatar
Journeyman Plumber
Getting Rid of Case Iron Piping from Boiler & Ceiling management General DIY Discussions 9 10-22-2013 06:52 PM
Using Y or T piping under sink for two sinks Wiscbldr Plumbing 3 11-09-2011 09:24 AM
What is light green 1/2" threated piping used for? stanlam Plumbing 2 07-15-2011 10:29 PM
Piping Layout for New Bathroom structman Plumbing 2 02-23-2010 06:24 PM
Copper Or Iron Piping? beatboy77 Kitchen & Bath Remodeling 2 01-03-2009 01:36 PM
