Fancy Thermostat Question - HVAC - DIY Chatroom Home Improvement Forum
Old 03-13-2011, 04:50 PM   #1
Still Learning
Fancy thermostat question
Hi all im working on a new project and i need some advice. Im installing a heat pump in a hydroponic grow room. The temp at the plants is 10 degrees hotter than the ambient temp at the stat. I know the honeywell th8000 has the capability of handeling 2 remote temp sensors but i need more than two. Does anyone know of a stat that can handle more than 2? I know its possible with a control board but that can be quite expensive. Thanks for your input
thehvacguy is offline   Reply With Quote
Old 03-14-2011, 06:18 AM   #2
AKA HVACTECHFW
Rewards Points: 1,208
Honeywell IAQ
If more than one remote indoor sensor is used, based on
configuration during installer setup, either of the following
options are available:
• The thermostat will display the temperature measured at
the sensor locations (internal thermostat sensor is
disabled). Sensors must be in square numbers (e.g., 4, 9,
16, and so on) and the displayed temperature will be an
average of the temperatures measured at each location.
• The thermostat will display a 50-50 average of the
temperature measured at the thermostat location and the
average of the temperatures measured at the remote indoor
sensor locations. In this case, the thermostat sensor still
carries a 50% weighting of the displayed temperature.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Thermostat issues rathipon HVAC 4 01-29-2011 12:46 PM
question on old thermostat wiring for upgrade jthn HVAC 2 01-03-2011 12:07 AM
Question on installing an Honeywell RTH6350 programmable thermostat. outdoorted HVAC 3 01-02-2011 07:48 PM
Two Wire 24V Thermostat to Digital Thermostat on Pellet Stove jrodtaclet Electrical 4 09-15-2009 06:37 PM
Thermostat question ctown HVAC 7 12-05-2006 04:46 PM
