Fan Wont Work - HVAC - DIY Chatroom Home Improvement Forum
Old 01-26-2009, 06:09 PM   #1
fan wont work
i have a lennox elite series oil furnece about 6 or7 yrs old and the fan will only work on the on setting and not on the auto setting lookin for some help
tutuffcustoms is offline   Reply With Quote
Old 01-26-2009, 06:12 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Check for 24 volts between G and common, or continuity between R and G on your tstat when it calls for fan. If no go, then you need to replace the tstat. Also, it may have a tstat in the heat exchager which locks out the fan until it reaches a certain temperature. This may be bad or need adjustment.
wirenut1110 is offline   Reply With Quote
Old 01-27-2009, 04:19 PM   #3
still no fan
thanks i put a new tsat on and and still no go i cleaned the limit too if i unplug the limit it kills the system so it must b good right or not? its got a mother board on it with relys on it could it b one of them.
Old 01-27-2009, 05:01 PM   #4
still no fan
Old 01-27-2009, 05:42 PM   #5
Rewards Points: 510
I'd post this over in HVAC, I'm sure there;s some oil burner experts over there. Sounds to me like a bad fan relay but they would be able to help you more.
Old 01-27-2009, 05:50 PM   #6
I just merged your threads together. PLEASE only post about an issue one time. Thanks.
Nathan
"He is no fool who gives what he cannot keep to gain that which he cannot lose." - Jim Elliot
Nathan is offline   Reply With Quote
Old 01-27-2009, 07:08 PM   #7
An old Tradesmen
Rewards Points: 6,072
Oil furnaces don't receive 24 volts from the stat to run the fan.
Not sure on the Elite if they use a delay timer, or a fan limit switch.
Old 01-27-2009, 07:16 PM   #8
Hvac Pro
yuri's Avatar
Rewards Points: 1,092
Post the model and serial# and I will look up the tech info on Davenet for you.
Can a homeowner perform electrical work in MA? dpd512 Electrical 77 04-11-2012 07:48 AM
Does your job require a permit? housedocs General DIY Discussions 203 12-01-2010 08:28 AM
Is it right that an owner must be licensed to perform work joey b Electrical 45 12-16-2008 11:16 AM
duct work framing kama Carpentry 4 11-15-2008 01:40 PM
Properly Sealing HVAC Duct Work craymer45 HVAC 5 11-06-2008 09:47 PM
