-   -   fan wont work (http://www.diychatroom.com/f17/fan-wont-work-36898/)
tutuffcustoms 01-26-2009 05:09 PM
fan wont work
i have a lennox elite series oil furnece about 6 or7 yrs old and the fan will only work on the on setting and not on the auto setting lookin for some help
wirenut1110 01-26-2009 05:12 PM
Check for 24 volts between G and common, or continuity between R and G on your tstat when it calls for fan. If no go, then you need to replace the tstat. Also, it may have a tstat in the heat exchager which locks out the fan until it reaches a certain temperature. This may be bad or need adjustment.
tutuffcustoms 01-27-2009 03:19 PM
still no fan
thanks i put a new tsat on and and still no go i cleaned the limit too if i unplug the limit it kills the system so it must b good right or not? its got a mother board on it with relys on it could it b one of them.
tutuffcustoms 01-27-2009 04:01 PM
still no fan
wirenut1110 01-27-2009 04:42 PM
I'd post this over in HVAC, I'm sure there;s some oil burner experts over there. Sounds to me like a bad fan relay but they would be able to help you more.:yes:
Nathan 01-27-2009 04:50 PM
I just merged your threads together. PLEASE only post about an issue one time. Thanks.
beenthere 01-27-2009 06:08 PM
Oil furnaces don't receive 24 volts from the stat to run the fan.
Not sure on the Elite if they use a delay timer, or a fan limit switch.
yuri 01-27-2009 06:16 PM
Post the model and serial# and I will look up the tech info on Davenet for you.
