Fan Won't Shut Off On Heatpump. - HVAC - DIY Chatroom Home Improvement Forum
Old 09-08-2009, 03:53 PM   #1
Fan won't shut off on heatpump.
I have an FHP Geothermal heat pump system to heat/cool my upstairs living space. It is a split system in that the compressor is under the house and the coils and air handling unit is in the attic. I have noticed over the last several months that even though the compressor kicks off, the fan will continue blowing for hours before it will eventually kick off. I can even turn the unit to the off position (switch on my thermostat) and the fan will continue to run. I have a digital thermostat and have even tried unplugging the thermostat from the wall but the fan continues to run. I have tried a new thermostat as well but the problem perisists. The unit heats and cools just fine. Is there a relay in the unit that would cause this and if so is this something I can easily locate and replace myself? Any help or suggestions would be greatly appreciated.
MERCOPTIMAX is offline   Reply With Quote
Old 09-09-2009, 11:13 PM   #2
I have the exact same problem! I was just about to try replacing the thermostat... I believe there is a relay on the fan, and it sounds like that has gone bad. I have never replaced one, so can't offer any advice. I'd probably hire someone to replace that... If you learn anything, please share.
Thanks,
Mark
beiley is offline   Reply With Quote
Old 09-10-2009, 07:25 AM   #3
Thanks,
Mark
Hi Mark, I don't think replacing your thermostat will fix the problem and the reason I say that is becuase I have the exact same thermostat on my downstairs unit. I tried switching them but it did not fix the problem. Hopefully someone else will reply on this string who has had the same problem before and will advise more details on the fix. Thanks !!!
Old 09-11-2009, 09:43 AM   #4
Thanks,
Mark
Mark, apparently this problem is a real stumper since no one has any suggestions on what the problem could be or a fix.
Old 09-16-2009, 08:45 PM   #5
I called an AC repairman who came out today. Apparently on my blower there is a small circuit board that adds a delay when turning off the fan. He said that was usually the problem. He just bypassed that circuit board and that fixed my problem. I don't have the specific details on how to bypass it, but it looked easy for him to do it. He also mentioned that sometimes the relays 'stick'. They get burn marks on the contacts, and can stick, leaving on the blower. Doesn't sound like that was my problem, but it is another possibility.
Good luck,
Mark
Beiley Software
Old 09-17-2009, 07:35 AM   #6
Good luck,
Mark
Beiley Software
Hi Mark,
Thanks for the update. I contacted the manufacturer of my unit and they said the possibilities were a circuit board (like you said) and that my unit heavily relied on relays. They felt like most likely mine was a relay sticking. I'll have to get a repair tech out to take a look. Sounds like yours was an easy fix. Pretty much just a rate per hour charge and that was it right? Thanks again for responding back.
Scott
Old 09-17-2009, 09:23 AM   #7
30 year tech
hvac122's Avatar
Surely the tech is going to replace the board and not just leave it by-passed? There is a reason it is there.
hvac122 is offline   Reply With Quote
Old 09-17-2009, 09:58 AM   #8
I asked about that, wondering the same thing. He said it was meant to improve the efficiency slightly by delaying the blower turn on until about 1 minute after the compressor turns on, and keeping the blower on for about 1 minute after the compressor turns off. He said it was minor, and many of the newer blowers don't even have them. He thought it wasn't a big deal to run without that delay board. Do you have a different opinion?
Thanks,
Mark
Beiley Software
Old 09-17-2009, 11:41 AM   #9
30 year tech
hvac122's Avatar
Efficiency is one reason for it. The other is for comfort. It takes a few minuites for the heat pump coil to get warm or cold depending on the season. The delay lets the coil do its thing so you don't get a blast of the wrong temperature air.
Also new units for the most part do all use this function. It may be adjustable as to how long the delay will be. Not sure on a FHP.
Shut Off Valve won't shut off DIY_Dumbie Plumbing 1 07-11-2009 02:22 PM
Community water shut off zevon Plumbing 14 10-03-2008 07:16 AM
Toilet to Go won't shut off Evildad Plumbing 4 09-28-2008 12:26 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
Toilet water Supply- Shut off valve kcreds Plumbing 5 04-07-2008 12:44 PM
