Old 12-22-2012, 06:58 AM   #1
fan won't shut off
I have an American Standard freedom 90 heater whose fan doesn't shut off when the heat temperature is reached. The heater does shut off, but fan keeps running.
macman50 is offline   Reply With Quote
Old 12-22-2012, 10:16 AM   #2
fan won't shut off
Make a easy check first.
At your thermostat make sure the Fan "On/Auto" is in the Auto position.
oncall is offline   Reply With Quote
Old 12-22-2012, 10:21 AM   #3
JOATMON
ddawg16's Avatar
fan won't shut off
Most of those have a temp switch in the air box that measures the temp of the air coming off the heater. It keeps the fan going until it has cooled down enough. Your unit should have a schematic....it's pretty easy to find the wires and use a voltmeter to measure.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
Can you solder within an inch of a closed shut off valve? amodoko Plumbing 17 08-16-2012 01:29 AM
Oil Furnace Emergency shut off switch location? LarryNH914 HVAC 19 06-28-2012 03:47 PM
Shut Off Valve won't shut off DIY_Dumbie Plumbing 1 07-11-2009 03:22 PM
Community water shut off zevon Plumbing 14 10-03-2008 08:16 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
