Fan Will Not Start In Cool Mode - HVAC - DIY Chatroom Home Improvement Forum
Old 06-24-2011, 05:59 PM   #1
Question
Fan will not start in Cool mode
I bought my house in January and am trying to turn my AC unit on for the first time. I can't get the fan to turn on in Cool mode. It works just fine in Heat mode. My furnace is a Lennox Pulse 21 and the outside compressor is also a Lennox. My thermostat is a LuxPro PSP722E that I installed in February of March to replace the old round non-programmable dial that was there. I'm fairly certain I installed it correctly.
Any ideas?
Thanks!
Skull Leader is offline   Reply With Quote
Old 06-24-2011, 06:31 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
what wires do you have to what terminals at the stat?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 06-24-2011, 06:39 PM   #3
Rewards Points: 6,652
hvactech126, I bet that either they forgot the rc/rh jumper, or wired it wrong. Sad thing is, this may be a one poster post as usually happens on weekends, so you may never find out what they did.
Old 06-24-2011, 07:35 PM   #4
After fiddleing with the wires I have come to the conclusion that the rc/rh jumper wasn't making a good connection because I had the two wires on the same side of the screw. Problem rectified. That was a simple fix; been puzzling over this for 3 hours now.
@gregzoll
I think you'll be seeing some more of me as I'm about to embark on the great highway that is DIY renovations.
Thanks for the quick responses guys!
Old 06-24-2011, 07:58 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 1,414
That furnace should have its heat exchanger pressure tested by a Lennox tech for safety every 4 yrs. Also the fan timer board may be obsolete and the retrofit is very expensive. I would start looking/budgeting for a new furnace as parts are hard to get for Pulse's as they have not been made for awhile and some of the specialized parts (gas flapper) are going obsolete as the companies who made them for Lennox are gone out of business due to the recession etc etc.
Old 06-24-2011, 10:05 PM   #6
No, just too many one post posters come on these forums and never return to tell us if they solved the problem or, just hitting multiple forums and possibly loose track. Hopefully with yuri's help, you should be able to get it solved.
Mini Splits - Always On & Auto vs. Cool function mobiledynamics HVAC 2 08-23-2010 03:39 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
Water from cold water faucet goes from cool to hot to cool tima2381 Plumbing 6 05-22-2007 09:02 AM
new 3 ton hvac Payne units. No cool air comes out when fan, compressor,thermostat run runbikeengr HVAC 10 04-10-2007 06:59 PM
