Fan Will Not Reverse - HVAC - DIY Chatroom Home Improvement Forum
Old 11-17-2011, 01:00 AM   #1
fan will not reverse
i have a american standard heat pump that i just installed in my home.its used, very used like 1999 used but was told it works.i noticed that when i swapped modes from cooling to heating my fan did not reverse.what causes it to reverse?the fan motor is a newer replacement so i was able to reverse it by swapping the reversing connectors but would love for it to do it on its own. wait isnt it suposed to reverse back on defrost?oops.it hasnt been cold yet for long so hopefully nothings broke yet.thanks
yodie213 is offline   Reply With Quote
Old 11-17-2011, 05:35 AM   #2
An old Tradesmen
Rewards Points: 6,592
The fan motor is not suppose to reverse. The fan runs in the same direction in both heating and cooling mode. A valve inside of the heat pump reverses. Only the refrigerant flow reverses, not the fan.
Old 11-17-2011, 08:12 AM   #3
when it first went into heating mode you could hear the fan trying to reverse.kinda like having one of the windings in the motor charging in reverse.the fan speed was reduced as well, intill i reversed the switch.fan speed then returned to normal but in reverse.
Old 11-17-2011, 09:03 AM   #4
HVAC Tech/Owner
Rewards Points: 604
The fan does not reverse, if it does you have a problem. the solution is not flipping the direction. the condenser is designed as a plenum and is always supposed to have the fan blowing out.
Technow is offline   Reply With Quote
Old 11-17-2011, 09:31 AM   #5
I'm Your Huckleberry
Rewards Points: 2,270
no fan ever changes polarity, direction.
Doc Holliday is offline   Reply With Quote
Old 11-17-2011, 01:18 PM   #6
not even a slit unit?strange a buddy of mine also changes direction with the different modes.we watched it do it just a few days ago.what would cause it to try to change direction. the tech that came out yesterday said it was suppoesed to too.said my csr was going bad and to replace it.he could be full of it i really dont know thats why questions are asked.lol
Old 11-17-2011, 04:43 PM   #7
An old Tradesmen
A weak capacitor can cause the fan to spin in reverse. BUT, the fan is NOT suppose to reverse. look at the fan blades, they only cut through the air when spinning in one direction.
The Following 3 Users Say Thank You to beenthere For This Useful Post:
ben's plumbing (11-17-2011), Doc Holliday (11-17-2011), yodie213 (11-17-2011)
Old 11-17-2011, 04:53 PM   #8
Ive dealt with that before.
The Following User Says Thank You to Doc Holliday For This Useful Post:
Old 11-17-2011, 07:51 PM   #9
went i went home today i swapped it back to blowing out but now im not getting any heat from my line and my unit is constantly using the aux heat?uh and the control board is flashing 3 times too
Old 11-17-2011, 07:52 PM   #10
An old Tradesmen
Read the error code on the panel.
Old 11-17-2011, 08:12 PM   #11
wow that clears it up there is like 7 things that could be wrong.grr
Reverse lights & top stop light Determined Automotive Repairs 5 09-20-2011 11:19 PM
Moving HVAC ducts/registers & reverse flow ?'s cbrc5eric HVAC 3 06-09-2010 06:05 AM
Ceiling Fan in Reverse? benchmarkman Appliances 10 01-18-2010 10:50 PM
HOT / NEUTRAL REVERSE.... need help to fix DIYneedsHelp Electrical 10 10-05-2009 07:36 PM
Kinetico Water Softeners -Reverse Osmosis Questions...Help - Advice wanted.. OverRunWithSons Plumbing 7 07-26-2009 01:14 AM
