Old 04-13-2011, 11:41 PM   #1
fan spinning wrong way
emerson k55hxweg-624 motor on heat pump spinning wrong way. Has two wires out the top of vent area which are orange and yellow which are connected to orange and yellow wire that run back into motor. Then 4 wires from motor running to condenser that at white, black, brown, brown/white. Brown and brown/white put into plugs in condenser area. white wire from motor connects to black wire and black wire connects of cream colored wire in condenser area.
homehealer is offline   Reply With Quote
Old 04-14-2011, 05:35 AM   #2
An old Tradesmen
Is this a new motor? Or has it been in for a while and was spinning the correct way?
If new, the wires at the top(orange and yellow) are the direction wires, just reverse them. If its an existing motor, the run cap may be bad and needs replaced.
Old 04-14-2011, 10:48 AM   #3
I just moved into the house. The fan blade looks brand new. The orange wire coming out of the top vent connects to orange as does the yellow to the yellow and directly back into motor. So swap yellow to orange?
Thanks for the reply. I really appreciate it.
Old 04-14-2011, 03:31 PM   #4
An old Tradesmen
Yep swap them to the different color.
Your welcome.
Water Heater, wrong connections? HAMP Plumbing 7 02-09-2011 11:57 AM
What am I Doing Wrong Here (Roller Marks, pics) dimswits Painting 12 01-14-2011 09:50 AM
maytag top load washer not spinning at times ed lee Electrical 2 01-07-2011 01:37 PM
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 03:44 PM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 09:13 AM
