Fan Shut Off When Heat Pump Comes On Troubleshooting - HVAC - DIY Chatroom Home Improvement Forum
Old 03-16-2011, 01:56 PM   #1
Fan shut off when heat pump comes on troubleshooting
Hi,
We're having a problem with the fan turning off when the heat pump comes on. I've replaced the motor, compacitor, and thermostat. But still the same problem. The fan works fine in emergency heat mode but when the Lennox heat pump comes on the furnace fan starts buzzing then turns off. Any suggestions as to what the problem may be that I can take a look at?
Parmleyhouse is offline   Reply With Quote
Old 03-16-2011, 04:53 PM   #2
Rewards Points: 380
How old is the air handling unit (furnace) you are working with? Sounds like it may be an older model that has a fan relay to start the fan in heat pump mode that isn't closing.
Is it by chance an electric furnace? Most have 2 relays to bring on the fan motor, one is 240 volt and turns on the fan when there is a call for emergency heat (through the sequencer), the other is operated off of 24 volts and gets it's signal from the thermostat (G terminal). Anybody tried changing the thermostat lately?
HVACDave is offline   Reply With Quote
Old 03-16-2011, 05:06 PM   #3
An old Tradesmen
Rewards Points: 7,808
Does the fan run when you turn the thermostat's fan switch to on?
Tags
furnace fan shut off
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 06:53 PM
New Heat Pump..questions? ddave23 HVAC 4 03-05-2010 05:13 AM
Heat pump vs in floor heat mugen HVAC 5 03-02-2010 08:18 PM
heat pump cut off set point oldswab HVAC 4 12-02-2009 02:09 PM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 10:28 AM
