Old 04-11-2008, 05:56 PM   #1
fan is not turning on
Hi everyone. I was hoping someone could give me a few pointers. I came home to a hot house yesterday so I opened the ac unit in the garage to take a look. It was nice and cold in there but the fan was not running. I switched the fan to "on" on the thermostat and it still won’t turn on. Could this be as simple as a fuse or something? How would I check? Thanks for the patience. I know nothing about AC systems.
nate28146 is offline   Reply With Quote
Old 04-11-2008, 08:30 PM   #2
HvacWiz's Avatar
First thing you need to do is verify if there is 120v to the motor. If not you probaly have bad circiut board or reley. if you have 120v then motor needs replaced.
HvacWiz is offline   Reply With Quote
HELP - Lost water pressure to shower after turning off water to house jpw28 Plumbing 8 02-20-2008 09:07 PM
Turning pilot light off jmcs23 HVAC 5 06-17-2007 09:38 PM
tap turns water on when turning left or right? ebonysw45 Plumbing 4 03-04-2007 02:48 PM
turning off water Jack Hass Plumbing 1 02-03-2007 10:00 PM
Turning valve at water meter KCnorthernCA Plumbing 15 10-23-2006 12:35 AM
