Fan Motor For Outside Unit Shuts Off - HVAC - DIY Chatroom Home Improvement Forum
Old 09-28-2012, 08:45 PM   #1
Fan Motor for outside unit shuts off
My fan motor for a Rheem Ruud condenser seized up. I called around and found a replacement. I wired it up according to the wiring diagram and even added a new capacitor like it said. It started fine and cold air started to come out of the vents. After about 20 minutes of it running it shut off. The motor was real hot and it tripped the reset button. I reset to button and it tripped again after just a couple of minutes. The original motor was 850 rpm and the replacement was 825 rpm. Everything else is the same. Can anyone tell me why it might be overheating?
BGordon72 is offline   Reply With Quote
Old 09-28-2012, 09:37 PM   #2
Missouri Bound's Avatar
Wrong voltage? Too small a replacement? Defective motor?
Do you want it your way or the right way?
Old 09-29-2012, 05:59 AM   #3
An old Tradesmen
Rewards Points: 6,468
Is it spinning backwards?
The Following User Says Thank You to beenthere For This Useful Post:
hvactech126 (09-29-2012)
Old 09-29-2012, 07:51 AM   #4
Rewards Points: 684
Blade installed wrong ???
SeniorSitizen is offline   Reply With Quote
Old 09-29-2012, 02:32 PM   #5
care to explain??
Old 09-29-2012, 06:39 PM   #6
Rewards Points: 684
Originally Posted by Missouri Bound View Post
care to explain??
Some blades can be installed upside down. More difficult on OEM because of the set screw location and easier to make that mistake on aftermarket.
Old 09-29-2012, 07:23 PM   #7
...and what would that do?
Tags
fan motor , overheated , shutdown
Can't get unit to turn on need electrical help please-wiring diagram included igotshocked Electrical 33 01-30-2014 06:13 AM
My A/C Unit only works in the day shuts down at night bnalamarie HVAC 4 09-07-2012 08:02 AM
Compressor Shuts Down When Temperatures are 95 or higher newseed HVAC 6 08-15-2012 06:57 PM
Can I upgrade the compressor in my RV roof AC unit? eoptrab HVAC 10 09-02-2010 05:43 PM
Evaporator unit is out under the house randyloy HVAC 1 08-29-2010 06:33 PM
