Fan Motor In Outside Unit - HVAC - DIY Chatroom Home Improvement Forum
Old 05-07-2009, 01:14 PM   #1
Fan motor in outside unit
hey guys, i just replaced the fan motor in my outside unit, it had seized up, and I am wondering how long you think it will take before the a/c starts to blow cold air again?
zosoplumber is offline   Reply With Quote
Old 05-07-2009, 02:58 PM   #2
An old Tradesmen
Rewards Points: 7,802
Depends.
Is it spinning in the right direction.
Is the compressor running. Sometimes they over heat and lock out for a few hours.
And how hot it is in your home.
Old 05-07-2009, 04:07 PM   #3
Actually, Im not sure which direction it should be spinning, its blowing air upwards, out of the unit, and its around 87 in the house(HOT!). I installed it a few hours ago. im hoping the compressor didn't burn out since the fan wasn't running for a period of time.
Old 05-07-2009, 04:08 PM   #4
How can you tell if the compressor is running?
Old 05-07-2009, 04:37 PM   #5
It pulls ~20A or more.
If you don't have a clamp-on ammeter you can use your house's wattmeter but you need to turn off everything else.
Old 05-07-2009, 04:48 PM   #6
thanks, I'll try that.
Old 05-07-2009, 04:55 PM   #7
An old Tradesmen
Grab the lager copper line.
If its cool or cold. The compressor is runnnig.
Even spinning backwards. Air will blow out the top.
Old 05-07-2009, 08:11 PM   #8
hey beenthere, will it take time for the larger copper line to start to feel cool, or should it have always felt cool even when fan in the unit wasn't working, I'm thinking since I hadn't notice the fan not working immediatly that maybe the condensor went because it was running without the fan running? make sense?
Old 05-07-2009, 08:16 PM   #9
An old Tradesmen
It should feel cool within a couple minutes.
You may have knocked a wire off, when you changedteh motor.
Or, your compressor may be toast from running without the condenser fan.
Old 05-08-2009, 01:24 PM   #10
thanks for the help.
Can't get unit to turn on need electrical help please-wiring diagram included igotshocked Electrical 33 01-30-2014 05:13 AM
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 10:11 AM
Central Air Outside Unit Cover czars HVAC 2 01-07-2009 10:23 PM
central unit will not come on ....please help guyasc HVAC 5 08-24-2008 05:10 PM
Wall unit AC drips water inside fw2007 HVAC 4 08-15-2008 10:07 AM
