Fan Limit Switch Question - HVAC - DIY Chatroom Home Improvement Forum
Old 11-01-2011, 12:23 PM   #1
Rewards Points: 14
Question for the experts regarding Honeywell fan limit switch:
in observing the movement of the dial during heating cycle, my dial does not move smoothly and slowly.....example: during cooling, the dial seems to get stuck on a temperature of say 100 degrees , then 'jumps' to 80 degrees to stop the fan.
Is this normal, or time for a new switch?
hr2pilot is offline   Reply With Quote
Old 11-01-2011, 12:30 PM   #2
biggles's Avatar
the pigtail is going when it cools or the switch might be weak breaking cheap change out from local GRAINGER there #2E820 the range and pigtail lenght is the thing to not on change out...how does it do heating up from 80 to 100+ the burner heat is on the tail but might be working into the contacts....
Old 11-01-2011, 12:57 PM   #3
Rewards Points: 14
hi biggles....
Ok, I just ran it through a heating cycle, it rotates slowly as heat increases.
If I tap the side of the switch with my finger, it will jump a bit, not as much as on the cooling.
Can the switch mechanism be cleaned or lubricated?
By the way, is 130 degree fan kick-in normal....it seem like that's kind of high.???? It takes a couple of minutes to get up to temperature begore high speed kicks in.....seems like a long time to me.
thanks
Old 11-01-2011, 01:24 PM   #4
biggles's Avatar
it's enclosed as you see with the cover off if you remove the control might snap the silver backing off and do a visual little WD-40 on the contact but it is very low end mechanical just turns and makes the fan or upinto hi limit.if it is stone cold the HEAT-X has to cook up so the pigtail expands and turns to close for fan.might want to go to 140F,but don't know what that HI SPEED is your refering to heating should run LO or Med LO for heating systems.if you don't feel a draft when the air comes out of the registers that is a bench mark for your system as much as a draft after the stat satifies burner off...then the fan cooling down and going off.can't do anything with the pigtail it's just metal heating and coolingNOTE if yo go to slip the controller out try to do it with the wires connected power off
Old 11-01-2011, 03:31 PM   #5
An old Tradesmen
Rewards Points: 6,088
Not uncommon for them to jump.
Old 11-01-2011, 03:44 PM   #6
Rewards Points: 14
thanks guys...won't hurt to change it i suppose.... furnace is 20 years old and new replacement parts online are pretty cheap to get the whole thing tuned up.
Old 11-01-2011, 03:56 PM   #7
biggles's Avatar
20 yrs is worth a change out heating and cooling doesn't owe you anything there just for pricing reference shop around... http://www.bestbuyheatingandaircondi.../fan&limit.htm
Old 11-01-2011, 06:21 PM   #8
newtech's Avatar
Rewards Points: 164
newtech is offline   Reply With Quote
Old 11-01-2011, 07:38 PM   #9
REP
It is a 50 year old design and your appears to be working as designed.
There is nothing unusual with a 130 degree cut in for the fan,that is normal too.
If you want it to come on quicker then the register tremature will be cooler.
Suggestion only as long as its working as designed,,,,leave it alone.
REP is offline   Reply With Quote
Old 11-01-2011, 08:09 PM   #10
Rewards Points: 14
Thanks for the advice guys!
Great website!
Trane limit switch mikethe ductman HVAC 7 01-18-2012 11:46 PM
Blower fan won't turn off - limit switch replaced Laplacian HVAC 4 02-14-2011 12:55 PM
Quick Bathroom Plug and switch Question mclemenc Electrical 5 01-30-2011 11:02 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 03:44 PM
Dayton 3E837 Limit Switch Question edanajo HVAC 11 12-04-2009 04:52 AM
