Old 01-31-2011, 11:04 PM   #1
Fan limit switch
I am replacing my fan limit switch and dont know how to determine if i need to remove the jumper for low voltage setting? Is there a simple way to tell if it is in a low voltage application?
crooked1 is offline   Reply With Quote
Old 02-01-2011, 02:56 AM   #2
HVAC Supermodel
unicursalhex's Avatar
Fan limit switch
should just be like for like, not sure what you're getting at
unicursalhex is offline   Reply With Quote
Old 02-01-2011, 04:52 AM   #3
An old Tradesmen
Fan limit switch
How many wires are on your old fan limit. If only 3, then you leave the jumper in. If 4, then you remove/break the jumper. Just look at your old one, and set up the new one the same.
heil 9000 limit switch problem? barryatnewton HVAC 1 01-02-2010 06:44 PM
Natural Gas Furnace Limit Switch 04gt HVAC 5 12-12-2009 08:50 AM
fan limit switch wiring to coil? honeywell luvheat HVAC 0 12-12-2009 04:03 AM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 02:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
