Old 12-10-2008, 10:49 PM   #1
fan limit control question
Replaceing cam stat fan/limit control w/ Honeywell L4064 B 2236 fan/limit. The cam stat has 6 wires. 2 fan, 2 limit, 2 time delay. Of the 2 time delay, 1 goes to the roll out switch and the other goes to the ignition module.
The Honeywell has for 4 connections. So, can I just disconnect the 2 time delay wires without having any problems?
Thanks ahead of time!
sbriggs_1 is offline   Reply With Quote
Old 12-11-2008, 12:03 AM   #2
hvaclover's Avatar
sure..............
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 12-11-2008, 08:09 AM   #3
You need to replace the fan/limit switch with a timed on switch or the blower may not function properly. Honeywell makes them as well.
SKIP4661 is offline   Reply With Quote
Wiring limit control on gas boiler uncleneiler HVAC 2 11-21-2008 02:54 PM
Wiring limit control on gas boiler uncleneiler Electrical 1 11-21-2008 09:03 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Aprilaire 700A Humidifier - Automatic control question feign3 HVAC 1 12-11-2007 05:31 PM
