The Fan On The Furnance Does Not Blow When On Auto, But Does When On... - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-27-2008, 09:07 AM   #16
An old Tradesmen
Rewards Points: 6,116
That would be the old tri pole second wave form diode model.
Last produced in 1974.
Old 10-27-2008, 09:08 AM   #17
An old Tradesmen
Originally Posted by woodheat View Post
I recently installed an outside wood burner shaver 165 with an exchanger in my rheem furnace plenum. the exchnager is heating up nicely. when I set the thermostat to auto, the fan will not come on. I shut off the propane supply line, so it sounds like the furnace is trying to light then recognizes that their is no gas, so it shuts off. If I put the fan setting to manual it runs great but runs all night. I just want it to come on when the temp demands it and then shuts off when the room temp is satisfied.
is there a way to make the fan come on and off thermostat dictates?
Does your stat have the ability to control electric heat.
If so, set it that the stat controls fan.
If not, get a fan control and install it above the coil.
Old 10-27-2008, 09:51 AM   #18
Jeeze Been, this is starting to sound like the other channel.
Next thing you know a guy named Robo is gonna show up.
hvaclover is offline   Reply With Quote
Old 10-27-2008, 09:59 AM   #19
the Musigician
DangerMouse's Avatar
now now, let's not get HIM involved!
DM
Old 10-27-2008, 10:00 AM   #20
An old Tradesmen
Lol...
Old 10-27-2008, 10:13 AM   #21
According to Winchester I am TOO involved.
But what the hey: You are both wrong about the sine wave inversion field density. The poly photon design makes it impossible for the stream to stay coherent enough to be tactile.
Old 10-27-2008, 10:33 AM   #22
the Musigician
you're right, of course, but ONLY if the silex ionizer is not working! don't forget that!
DM
Old 10-29-2008, 01:25 PM   #23
Originally Posted by Sojo View Post
I have a Heil gas furnance. when i turn it on auto to come on and off when it reaches 68 i can hear it start up, but the fan does not kick in and blow. but if i turn it on "on" the fan is working. I changed the thermostat out and it still does not work.... thanks for any help...
Replace the fan switch, the fan switch operates by tempature!
simpleman
simpleman1962 is offline   Reply With Quote
Furnance burner won't stay on. 2007ken HVAC 11 03-04-2008 12:29 AM
oil furnance "boom" when starting hvac novice HVAC 5 11-21-2007 01:56 PM
Blow in insulation Iowabucks General DIY Discussions 1 10-09-2007 09:20 AM
blow power of vents mcvane HVAC 5 08-11-2007 04:28 PM
