The Fan On The Furnance Does Not Blow When On Auto, But Does When On... - HVAC - DIY Chatroom Home Improvement Forum
Old 10-26-2008, 06:27 PM   #1
The fan on the furnance does not blow when on Auto, but does when on...
I have a Heil gas furnance. when i turn it on auto to come on and off when it reaches 68 i can hear it start up, but the fan does not kick in and blow. but if i turn it on "on" the fan is working. I changed the thermostat out and it still does not work.... thanks for any help...
Sojo is offline   Reply With Quote
Old 10-26-2008, 06:33 PM   #2
the Musigician
DangerMouse's Avatar
is there heat coming out when the fan is on?
DM
Old 10-26-2008, 06:34 PM   #3
Is there a call for heat? Crank the thermostat up when it's on auto and see what happens,
jerryh3 is offline   Reply With Quote
Old 10-26-2008, 07:36 PM   #4
sorry about that
I am sorry i had problems replying..... the air is cold when it blow when the fan is on on
Jsojomoore is offline   Reply With Quote
Old 10-26-2008, 07:54 PM   #5
the Musigician
go ahead jerry, i gotta get to bed... pressure switch?, dead birds/mice in updraft tube? will the mysteries never cease? nite all
DM
Old 10-26-2008, 08:00 PM   #6
oh that does not sound good.... mice, birds,,,, no no.... i would do the electric stuff or circut stuff but not dead animals...thanks,,,,, j
Old 10-26-2008, 08:40 PM   #7
HvacWiz's Avatar
Rewards Points: 252
Circuit board probaly needs replaced.
HvacWiz is offline   Reply With Quote
Old 10-26-2008, 09:21 PM   #8
Smile
thanks...
Old 10-27-2008, 06:43 AM   #9
the Musigician
anything is possible at this point. how old is the furnace? (might not even have a circuit board) can you post a picture? will SD515 fly in, cape billowing and save the day? will 8-Ball roll along with his giant bag of tricks and have the answer? stay tuned tomorrow to this network and find out! same bat-time, same bat-channel!
DM
Old 10-27-2008, 07:23 AM   #10
An old Tradesmen
Rewards Points: 6,928
Limited info.
Permits wide guessing.
Old 10-27-2008, 07:25 AM   #11
Originally Posted by beenthere View Post
Limited info.
Flux capacitor?
Old 10-27-2008, 07:45 AM   #12
the Musigician
if it was the flux capacitor, there'd be green slime on the flammistat where it connects to the potentio valve, wouldn't there?
DM
Old 10-27-2008, 07:51 AM   #13
An old Tradesmen
Only if it was an inversed sine wave model.
Old 10-27-2008, 07:56 AM   #14
rheem 90 plus classic won't turn on fan
I recently installed an outside wood burner shaver 165 with an exchanger in my rheem furnace plenum. the exchnager is heating up nicely. when I set the thermostat to auto, the fan will not come on. I shut off the propane supply line, so it sounds like the furnace is trying to light then recognizes that their is no gas, so it shuts off. If I put the fan setting to manual it runs great but runs all night. I just want it to come on when the temp demands it and then shuts off when the room temp is satisfied.
is there a way to make the fan come on and off thermostat dictates?
woodheat is offline   Reply With Quote
Old 10-27-2008, 07:58 AM   #15
the Musigician
now hold on there.... ANYone knows if it was a inversed sine wave model, the slime would be blue!
DM
Furnance burner won't stay on. 2007ken HVAC 11 03-03-2008 11:29 PM
oil furnance "boom" when starting hvac novice HVAC 5 11-21-2007 12:56 PM
Blow in insulation Iowabucks General DIY Discussions 1 10-09-2007 08:20 AM
blow power of vents mcvane HVAC 5 08-11-2007 03:28 PM
