Fan Doesn't Start Without Assistance. - HVAC - DIY Chatroom Home Improvement Forum
Old 08-03-2010, 02:05 PM   #1
Fan doesn't start without assistance.
I have a RUDD Heat pump unit that won't restart after it shuts down. When the unit starts up after a shut down the compressor comes on, but shuts down after a few minutes because the fan doesn't come on. If I hit the reset button on the unit after a cool down period and then gently give the fan a little nudge then it starts right up and works fine.
Paul T is offline   Reply With Quote
Old 08-03-2010, 02:20 PM   #2
Rewards Points: 81
Probably a bad capacitor.
Jack Olsen
The 12-Gauge Garage website
My Car
Jack Olsen is offline   Reply With Quote
Old 08-03-2010, 03:02 PM   #3
you need a "run start capacitor" very easy to install just make sure yoiu get the right one
mkgilliam is offline   Reply With Quote
Old 08-03-2010, 03:12 PM   #4
But check the cap you have just in case it is not bad, or it is bad and there are other problems causing it to be bad.
Air Compressor blowing start capacitors? BBC3 Electrical 9 04-28-2013 12:34 PM
Do you start gable soffit from the top down?? 4just1don General DIY Discussions 8 10-16-2009 06:20 PM
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Tools 2 08-26-2009 09:26 AM
Brand new PAYNE PG9MAB won't start . Error code 12 tp618 HVAC 3 12-19-2008 10:21 PM
Blue smoke at start up, and shudder at idle fauer Automotive Repairs 6 08-22-2008 12:39 PM
