Fan Does Not Work In "auto" Mode On My Lennox Pulse 21 Gas Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 01-22-2009, 08:09 AM   #1
Question
fan does not work in "auto" mode on my Lennox Pulse 21 gas furnace
My Lennox Pulse21 has worked fine for the last several years, then I removed the thermostat to paint the walls (just the module; didnt disonnect the wires) and it was off the wall for about 2-3 months. Once I put it back on, the fan would never turn on in "auto" mode. It only works in the "on" mode. I tried a new thermostat and it did the same thing so I put the old one back on.
To run the heater I first turn on the heat, then the fan. Once the house gets to the proper temperature, I then turn the heat switch to "off" and the fan switch off, or actually "auto" mode until it gets cold in the house where then I repeat the process.
Can anyone help me or possibly point me in the right direction?
Thank you!
Oliver
oliver.mogan(at)yahoo(dot)com
OliverMogan is offline   Reply With Quote
Old 01-22-2009, 08:54 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 376
That furnace has a nasty timed on circuit board to start the fan with the burner and it may be faulty. May be a coincidence that it failed now. It is very expensive/almost obsolete and a difficult/ not DIY/ retrofit/project. Call an EXPERIENCED Lennox Pulse tech.
For all you Lennox owners ibwahooka HVAC 9 11-23-2008 04:06 AM
furnace won't work canadaclub HVAC 2 03-10-2008 01:40 PM
furnace cycles, runs for 45-60 seconds shuts down and recycles again ronsmoneypit HVAC 4 02-03-2008 01:46 PM
Gas furnace just barely does not work. Halcyon HVAC 9 12-27-2007 11:28 PM
Heil furnace Won't work. mgbarber44 HVAC 2 11-25-2007 02:34 PM
