With Fan ON, Cooling Runs All The Time - HVAC - DIY Chatroom Home Improvement Forum
Old 02-09-2011, 04:55 PM   #1
With fan ON, Cooling runs all the time
Have a 2 yr old Carrier Heat Pump/ Honeywell Thermostat.
When I turn the fan to the ON position, no matter where I have the thermostat set, or even with the system set to OFF, the unit continues to cool - the compressor is on all the time the fan is running.
COntacted Honeywell - did diagnostics on THermostat - it is OK. Even wired to bypass the thermostat, and still the unit Cooled whenever the fan was ON.
Contacted Carrier - they told me to contact Climate Master, who makes the Water-source heat pumps for Carrier. They've been totally nonresponsive, but I see nothing on their website that looks like my unit.
Two A/C contractors have been unable to find a cause for the compressor to be ON whenever the Fan is ON.
Any suggestions?
coachgns is offline   Reply With Quote
Using A/C for first time after home reno. Not sure if this is normal operation. the punisher HVAC 7 05-25-2010 07:42 PM
runs and sanding oscarMadison Painting 1 02-24-2009 06:46 AM
Bryant Plus 80 Code 33 fan runs all time! ideas? westomaha HVAC 1 12-25-2008 12:09 PM
Fan runs constently Furnace won't fire BSO HVAC 1 11-16-2008 09:40 PM
PEX Manifolds: home-run to each fixture vs grouping runs? drh Plumbing 3 04-02-2008 04:44 PM
