Fan Continues To Blow - HVAC - DIY Chatroom Home Improvement Forum
Old 10-09-2010, 10:45 AM   #1
Fan continues to blow
Heat and AC is off, fan is on auto. The fan continuhes to blow even though the system is not on. What could cause this problem.
kd6j5z is offline   Reply With Quote
Old 10-09-2010, 12:31 PM   #2
we need more info to be able to help out.
hvaclover is offline   Reply With Quote
Old 10-12-2010, 06:12 PM   #3
Turned the heat on the other day, operated just fine, then it starting blowing cold air. The unit has a electric pilot light. The termostate is on auto and is set on heat. The blow just continues to run, I turned it off from the power switch located on the unit and it stopped. When I turn it back on the blower operates again and the pilot will not light.
Old 10-14-2010, 11:24 AM   #4
Rewards Points: 460
Monitor new thread of user chavez36 dated 13/13.
diyorpay is offline   Reply With Quote
Flourescent Light Ballasts continue to blow out! Please Help! chino Electrical 6 06-26-2010 10:29 AM
Air Handler will not blow Holysmoke99 HVAC 4 04-30-2010 03:18 PM
what compressor can I use to blow out sprinkler system? Leoskee Landscaping & Lawn Care 12 02-04-2010 05:07 PM
Blow in insulation Iowabucks General DIY Discussions 1 10-09-2007 09:20 AM
blow power of vents mcvane HVAC 5 08-11-2007 04:28 PM
