Old 12-20-2007, 07:33 AM   #1
Fairley new furnace needs help
This is my first time here. Please help!
I am having a problem with my furnace, when I kick the heat up the Induced fan comes on, after 30 seconds the burner comes on then gos out again, after about 30 seconds it comes on again then gos out again, it will not stay lit long enough for the blower motor to come on. If anyone has any
suggestions it would be very much appreciated.
shoecobbler is offline   Reply With Quote
Old 12-20-2007, 11:20 AM   #2
It sounds like a dirty or faulty flame sensor. You can try cleaning the sensor with steel wool to see if that corrects the problem. The sensor is usually a steel rod sitting in the flame of the last burner with a single wire going to it.
cjett is offline   Reply With Quote
Old 12-20-2007, 02:21 PM   #3
Yep, as cjett said it's usually the flame sensor when it does that.
Old 12-20-2007, 09:40 PM   #4
Thank you for you help, I will try that tonight
Old 12-21-2007, 02:13 AM   #5
Thank you for all your help, I cleaned the sensor and so far it seams to be working fine
Old 12-21-2007, 10:44 AM   #6
Glad to hear you have heat.
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
Furnace not firing jax HVAC 5 02-22-2009 01:41 PM
Furnace Help tuasoi HVAC 2 11-29-2007 01:54 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
