Extra Insulation For Air Handler? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-03-2011, 06:33 PM   #1
I live in S. Texas, where 100+-degree temps are common in summer. The air-handler is attic mounted - due to insufficient attic ventilation (which I'm also working on), attic temps get upwards of 135 on a 100-degree day.
As I said, I'm working on the ventilation issue, and I'm also slowly replacing the R4-insulated flex ducts with R8 ducting. Since the air handler is sitting in all this heat, I'd like to improve it's insulation as well. One method I've thought about is rigid-foam sheets strapped/glued around it (with access to the access panel) - any other ideas? And is this worth it (bearing in mind this would also help in winter)?
Thanks!
texasprd is offline   Reply With Quote
Old 06-03-2011, 07:50 PM   #2
An old Tradesmen
Rewards Points: 7,816
http://www.reflectixinc.com/basepage...&PageIndex=674
The Following User Says Thank You to beenthere For This Useful Post:
texasprd (06-03-2011)
Old 06-03-2011, 09:50 PM   #3
Thanks, beenthere!
Looks like the R6 duct insulation could work pretty well - was that what you had in mind?
Old 06-04-2011, 07:06 AM   #4
An old Tradesmen
Yep, it knock several thousand BTU off of your ducts heat gain and or loss.
Old 06-04-2011, 07:43 AM   #5
The ducting is almost entirely flex duct, with distribution triangles to split it off. I want to insulate the air handler, and it looks like I could use the duct insulation product (I assume it's meant for sheet metal/fiberboard ducts) around the air handler.
Old 06-04-2011, 08:31 AM   #6
An old Tradesmen
You can use it on the air handler. As long as you leave access to the panels for future service.
Old 06-04-2011, 08:44 AM   #7
Absotively and posilutely! I clean the indoor & outdoor units myself, so I'm definitely going to leave access.
Old 06-04-2011, 09:07 AM   #8
Hvac Pro
yuri's Avatar
Rewards Points: 140
Don't know how you guys survive in 100-135 deg F attics. I only see 1 or 2 a year. -40F I can handle, just put extra clothes on but you can only strip down so far and that insulation is awful itchy on bare skin.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 01:54 PM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 02:10 PM
Shed roof addition & insulation qustion radgumbo Roofing/Siding 2 12-06-2010 05:33 AM
Adding attic insulation pomelo Building & Construction 3 10-22-2009 05:19 PM
