External Gauge On Supply Line? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-01-2011, 10:16 PM   #1
Rewards Points: 14
External gauge on supply line?
I have a gas boiler furnace. There is a gauge clamped
to the supply line. It has a dial that is set for 200 degrees.
It also has 2 wires that go to the aquastat. What is that and whats it function?
draft34 is offline   Reply With Quote
Old 11-01-2011, 10:34 PM   #2
Rewards Points: 380
Sounds like your high limit control. Should be wired in series with your aquastat to turn off the burner if your thermostat were to get stuck in the on position. Acts as a safety that's why it's set to 200, makes sure it cuts off your burner before the water starts to boil in the system.
Your Aquastat is your operating control which is likely set at 160-180?
HVACDave is offline   Reply With Quote
Old 11-02-2011, 05:57 AM   #3
Rewards Points: 14
Yes the aquastat is set to 180. So if its a high limit control switch in series, then it should be normally closed when the temperature of the copper pipe is less than 200, then opens when its 200?
Old 11-02-2011, 06:30 AM   #4
AKA HVACTECHFW
Rewards Points: 1,208
Yes, that is correct
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Removing this type of supply line from bathroom faucet? dveiga Plumbing 5 04-24-2011 08:58 AM
leaky copper fitting in supply line for fire sprinkler system tina2435 Plumbing 5 09-18-2009 09:54 PM
Water supply line replacement bamaknox Plumbing 2 01-08-2009 08:51 AM
add an additional register to a supply line b2v HVAC 1 06-20-2006 06:55 PM
hot pilot light supply line dlkk HVAC 1 02-24-2006 05:45 PM
