-   -   External Furnace Filter (http://www.diychatroom.com/f17/external-furnace-filter-163178/)
Frank_Water 11-13-2012 07:24 AM
2 Attachment(s)
I had a new furnace installed that required an external furnace filter. The tech did not have an external filter rack for the unit, so he cut a slot in the return air vent and slid the filter in the slot. It sticks out about 3" and just doesn't seem like the proper way to have a filter installed on a new furnace. Any thoughts... want to be sure this is proper and going to be safe and efficient. Attached are a few pics.Attachment 60433
Attachment 60434
HVACDave 11-13-2012 10:59 AM
Seen many done in a similar fashion and it will work. Doesn't look nice and if your pic showed the way the return ties into the duct at the top we could tell you if you have room to slide the return drop over and add a filter rack on the side of the furnace.
HVACTECH96 11-13-2012 05:58 PM
Remove filter and look into slot to see if there is a track to support filter around the edges inside the duct,not just a couple long screws in the back.
Doc Holliday 11-13-2012 06:16 PM
Lame install. :yes:
Marty S. 11-13-2012 06:23 PM
Have him make a door to cover the thing at least. The angle or location of the filter is not a problem though.
Doc Holliday 11-13-2012 06:30 PM
This is a filter cabinet for a media filter but they make these for your regular thin filter that you have there as well. But your filter is far too big if it's protruding so far.
Lame. Do what Marty suggested at the least.
http://r1.cygnuspub.com/files/cygnus...n_QUR_3346.jpg
Missouri Bound 11-13-2012 06:47 PM
You say "tech", I say "hack". Sure it's done, but a filter shouldn't be an afterthought...it's an integral part of the installation. Are there rubberbands or tape holding it in place?:laughing:
Frank_Water 11-13-2012 07:44 PM
Thanks for validating what I was thinking. I called and asked them to come back out. The humidifier is also not working ... they will have to look into that as well. In my old house, the filter was a big box/compartment that attached between the furnace and return duct. It was like an air cleaner type of system. Should I consider that rather than a typical filter?
how 11-13-2012 08:37 PM
This is the kind of filter set up that usually happens when an owner complains that their current furnace filter set up within the furnace is too awkward to access. It's passable as an easier convenience for the owner of a furnace and ducting that has already been installed but is pretty much a hack job for a new furnace instalation where proper filter planning is part of the job.
My bigger complaint about it comes from that section of the return air below it that from the size of it must feed from elsewhere and bypasses the filter.
ben's plumbing 11-13-2012 08:57 PM
my thougth also how ..it must access another location or it should have been removed for a proper filter boot...ben sr:yes:
how 11-13-2012 09:13 PM
Sorry Ben.
These old eyes might be seeing the floor at the bottom right as part of a larger boxed return air.
Might be time for me to switch those generic drug store reading glasses in for something more personal.
ben's plumbing 11-13-2012 09:19 PM
Originally Posted by how (Post 1051716)
Sorry Ben.
well then we both must get new readers because iam seeing the same thing....but as i look at it yep thats the floor..:laughing::laughing::whistling2: iam good ben sr
