07-06-2009, 11:24 PM
#1
Exterior dryer vent covers
I have a problem with birds nesting in exterior dryer vents. My vents are wall mounted on a brick exterior. The flap type don't prevent the nesting, as they hang open enough to let the small birds in. I have seen the Heartland vents on the web...do they work? Any other suggestions? Thanks.
07-07-2009, 07:49 AM
#2
HVAC / Plumbing
This is what I install for vent termination  Birds can't get in
07-07-2009, 09:32 AM
#3
Learning by Doing
I found one that has a small grate that easily snaps on and off so I can clean off the excess lint.
If I could only remember to THINK about what I was doing before I did it.
07-07-2009, 11:23 PM
#4
What type of professional tradesman installs these? HVAC contractors?
07-08-2009, 07:56 AM
#5
HVAC / Plumbing
Can't speak for everyone else... It may not be exactly like this . but It's close. If you've installed any ..You should know that there are many on the market...The ones I install are approved for dryer venting.. gas or elec.
07-08-2009, 03:27 PM
#7
Hvac Guys with a lot of time on their hands
sorry ken...couldn't resist a friendly jab.
Just slow, not stupid.
07-08-2009, 04:26 PM
#8
HVAC / Plumbing
I owe you one
In this economy ... A guy's got to do what a guy's got to do..  . Replaced a toilet yesterday... Of course, I'am also a plumber... Don't like it that much... But, whatever pays the bills
07-08-2009, 08:24 PM
#9
The pick you posted is only for air conditioned environments though right?
It's not for an attic application where the tube would need to be insulated.
BTW per code, is a 4" diameter rigid tube required for the attic?
I've never seen insulation for rigid tubes sold at the big box stores though.
07-08-2009, 10:19 PM
#10
HVAC / Plumbing
Depends on the area your in as to what code would be... Any metal dryer vent is code here ... insulated ??? Not required here... I was only refering to the termination part of the vent to keep birds out.. not the entire vent package... You would need to install what ever is code for your area... Insulated or not
07-10-2009, 05:01 PM
#11
Thanks to all...good info. I'll try the louvered one.
10-29-2010, 07:24 PM
#12
One should check the manufacturer's restrictions to ensure it's for the right application. I've seen those at the HD, and they clearly state not for dryer vents.
10-29-2010, 08:49 PM
#13
Chicago, IL
What the dryer manufacturers typically recommend ( always follow the specific installation and use instructions for your dryer):
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
10-29-2010, 10:07 PM
#14
Yes, and the ducting is rigid vice flex.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
