Extending Finished Attic Insulation Stops? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-08-2009, 11:00 PM   #1
Extending finished attic insulation stops?
Hey everyone,
I have a garage that we built about 2 years ago with alot of help from friends and family. My father in law showed me how to install the insulation stops for the attic and everything has been going good.
Now though, I'd like to add insulation to the garage attic (blow it in) and the insulation stops end right at the height of the current R 20 attic insulation.
I know that if I want to blow in more insuation I'll have to somehow extend those stops to keep the new blown in stuff from blocking the vents. 23" on centre rafters... If I took one of the 23" foam attic stops they sell at say HD...divide it in half and slide it down the current cardboard stops... will that provide enough ventilation if the rest of the soffit vent gets plugged from the blow in?
I hope I'm making this clear enough...heh heh. Any ideas would be greatly appreciated. There is just "crawl room" up there..and even at that...I'll be having to sqirm around on supports to make sure I don't fall though the roof drywall.
If I'd have known anything about insulation stops before we built the garage I would have done it the right way...but the father in law has built 3 homes on his own...I figured he knew pretty much everything.
Thanks in advance.
Mitch in Canada
Mitch H is offline   Reply With Quote
Old 12-09-2009, 01:04 AM   #2
normally garage attics arent insulated at all are you converting to a room
kennzz05 is offline   Reply With Quote
Old 12-09-2009, 12:00 PM   #3
Hi Ken,
It can get to minus 55 up here in winter. Having the garage attic insulated is a must if you hope to hold in the heat.
Mitch
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 01:42 PM
Faced or Unfaced Insulation in Attic??? capenpeck Building & Construction 13 11-06-2009 08:23 AM
Remove old insulation in attic? powerman4160 Building & Construction 10 01-30-2009 05:12 PM
un-vented attic insulation questions.... roadk Building & Construction 12 09-18-2008 07:54 AM
adding Insulation to finished basement Mr Chips Remodeling 2 03-23-2008 11:16 AM
