Exposed Ductwork In A Finished Basement - HVAC - DIY Chatroom Home Improvement Forum
Old 02-08-2011, 02:26 PM   #1
exposed ductwork in a finished basement
i am finishing the basement and was thinking of leaving the ductwork exposed. does it need to be insulated? I am told it might condense water and drip. True?
peter weiler is offline   Reply With Quote
Old 02-08-2011, 02:34 PM   #2
fabrk8r
fabrk8r's Avatar
I doubt if you will have a duct condensation problem in your basement unless you have a humidity problem in the summer time or your basement is unusually warm compared to most.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 02-08-2011, 05:27 PM   #3
Check if local code permits that. Otherwise not needed.
Suggest covering it for aesthetic reasons.
hemanth12 is offline   Reply With Quote
Old 02-09-2011, 12:49 AM   #4
HVAC Supermodel
unicursalhex's Avatar
Rewards Points: 150
If you're finishing the basement and its going to be a conditioned space you don't have to worry about it.
unicursalhex is offline   Reply With Quote
Old 02-09-2011, 03:25 AM   #5
An old Tradesmen
Rewards Points: 7,356
Only if your basement has a high humidity problem after you finish it. A dehumidifier will take care of that.
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
Moving ductwork in basement Manicboss HVAC 2 03-22-2012 03:07 PM
Vapor barrier requirement for finished basement JTK Building & Construction 13 02-05-2011 04:30 PM
Partially finished Basement HVAC l22 HVAC 1 01-24-2011 12:22 PM
Tapping into basement ductwork BasementVirgin HVAC 7 09-10-2009 09:01 PM
