Expensive Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 01-17-2007, 03:32 PM   #1
expensive heat
I own a thirty year old A frame that has been remodeled. The house is expensive to heat and cool, I don't know if the funnace was installed correctly and , or proper attic ventalation. Is there a diagram or insructions of how this system should be installed? It is a Ducane model# SG10B30075. I know I have some insulation issues but the unit is not that old and should be more eficient.
Aframeowner is offline   Reply With Quote
Old 01-17-2007, 03:41 PM   #2
Thoroughbred Mopar Man
Rewards Points: 502
Hi Aframeowner
Judging by the model number you have posted, you have extremly low end or what we call builders or spec equipment. You are probably getting the best you are going to get out of it.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
Old 01-18-2007, 02:01 AM   #3
Old 01-18-2007, 02:34 AM   #4
I will check but I am not sure if the roof is vented, how important is it and would it help.
heat wont come on with t-stat in auto wahanks HVAC 5 02-07-2014 11:08 AM
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 11:22 PM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 01:27 PM
Steam Heat still making banging noises helpless handyman HVAC 101 01-04-2008 04:43 PM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 09:57 PM
