Expansion Tank Location?? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-05-2009, 11:41 AM   #1
Expansion tank location??
I have a multi zoned (1 pump per zone) gas fired HW base-board heating system. Where should the diaphram expansion tank & make up fill water be located? I'm getting conflicting info from Weil-McLain and Amtrol. Amtrol states the make up water and expansion tank should be connected to the supply side at the pump suction. Weil McLain states the make up water and expansion tank should be connected to the return line prior to entering the boiler. I plan to install an air seperator with air vent on the supply side to minimize air in the system.
rcassidy is offline   Reply With Quote
Old 10-05-2009, 12:04 PM   #2
It is best to install the expansion tank just before the suction side of the circulation pump. don't forget to properly fill the air side with proper amount of pressure.
either before the boiler or at the suction side of the pump would still be the same...but for flow conditions, install on suction side of pump.
Viper16 is offline   Reply With Quote
Old 10-05-2009, 08:44 PM   #3
tk03's Avatar
Rewards Points: 150
The air separator should be on the supply side of the boiler. As you heat water it starts driving the air from the water. Your air separation will be better on the hot side.
tk03 is offline   Reply With Quote
Old 10-06-2009, 10:01 AM   #4
Viper16- thank you for reply, thats what I thought. My boiler was pipped totally incorrect, I have a lot of air in the system, I will repipe asap..... thanks again
Old 10-06-2009, 10:01 AM   #5
thank you, that is what I thought as well...
Hydronic expansion tank mounting Joe F HVAC 3 09-28-2009 05:17 PM
Hydronic expansion tank Joe F HVAC 4 09-07-2009 05:48 PM
Installing new expansion tank ted schumm HVAC 2 07-19-2009 10:49 PM
Hot water heater expansion tank? rjniles Plumbing 3 06-21-2008 11:53 AM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
