Exixting Analog Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 06-19-2015, 01:37 PM   #1
Rewards Points: 4
exixting analog thermostat
can I replace a regular old thermostat to a digital thermostat for a 3 ton heat pump without much trouble, thanks in advance
dawarren is offline   Reply With Quote
Old 06-19-2015, 01:49 PM   #2
Rewards Points: 1,989
I have yet to figure out why anyone would want to ?
The old mercury bulb Honeywell tstats last a LONG time .
God bless
Wyr
WyrTwister is offline   Reply With Quote
Old 06-19-2015, 03:29 PM   #3
An old Tradesmen
Rewards Points: 7,304
Yes you can.
The Following User Says Thank You to beenthere For This Useful Post:
gregzoll (06-22-2015)
Old 06-19-2015, 04:44 PM   #4
May help if the common wire is present at the tstat . I think some electronic tstats need it . Some get by w/o it , bu using batteries ( I think ) .
Last thing I need is a WiFi tstat . I think some do this , some probably do not ?
But , have fun .
God bless
Wyr
Old 06-19-2015, 06:23 PM   #5
Rewards Points: 7,672
Watch out for wire terminal labels - they aren't always consistent.
The digital stats have to be setup for heatpumps.
Electronic will bring the back up heat on sooner without as much as a temperature swing. Just hit hold when the heatpump runs in heating mode, otherwise you'll be using strip heat to recover from setbacks.
user_12345a is online now   Reply With Quote
Old 06-19-2015, 06:32 PM   #6
Rewards Points: 1,236
Yes you can and hurry. Buy the most expensive Honeywell you can find because i have a little HON stock.
SeniorSitizen is offline   Reply With Quote
Old 06-21-2015, 07:21 AM   #7
Rewards Points: 48
dawarren
ck your PM
Rocky in NM
rockinnm is offline   Reply With Quote
Old 06-22-2015, 12:21 AM   #8
Rewards Points: 4
thanks to all,,,especially Rocky,,,you rock!
Old 06-22-2015, 01:37 AM   #9
Rewards Points: 6,652
dawarren just follow the installation instructions for the new thermostat. Personally I would stay away from the Nest. Still too many software issues. The 3m-80 with the MyCloudbeam.com radio module would work with your setup. It also gives you outside temps and humidity, which are controlled through the website.
If you go with one of the Honeywell thermostats, remember that the lower end ones for Wifi control, do not work with third party control software.
It all really depends on if you want to control it while away or from say your chair or bedside, or you want a set & forget.
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 04:32 PM
Wiring on Hunter Analog Thermostat woomama HVAC 16 03-22-2010 01:52 PM
Analog thermostat to digital thermostat conversion problem godcomplex HVAC 8 01-13-2010 02:50 PM
Upgrade RV analog with Honeywell Thermostat Ray Wallace HVAC 3 08-13-2009 12:34 PM
