Exhaust Venting Through Rim Joist - HVAC - DIY Chatroom Home Improvement Forum
Old 02-26-2012, 11:08 PM   #1
Just curious what the ontario building code says about this.
Im installing a bathroom exhaust fan in a basement and need to put the 4" ducting through the rim joist (I know the hole should be centered) but in the OBC is there an allowable hole size that can be put through the exterior rim joist? I mean its ffully supoorted below by a continous plate and teh oundation.
Ive heard before that the allowable hole size is one third of the size of the joist meaning in a 2x8 rim joist I would only be able to cut out a 2 3/8" hole? Not sure if this is true or not. Anyone know?
ordonyez is offline   Reply With Quote
Old 02-26-2012, 11:40 PM   #2
Registered User
Rewards Points: 526
Just call your local AHJ. The rim joist is fully supported, a fan hole is probably acceptable as long as a point load is not directly above it (then there would be solid blocking existing). May have difficulty if too close to the ground for snow load stopping back-flapper operation... may require x distance from house openings...etc.
Gary
P.S. I'll move you to HVAC.
Old 02-27-2012, 11:16 AM   #3
Just got an answer from the building department.
A rim joist is permitted to be drilled if it is non-load bearing ( i.e., not acting as a lintel for an opening )
The Following 2 Users Say Thank You to ordonyez For This Useful Post:
ben's plumbing (02-27-2012), Gary in WA (02-27-2012)
Gas Furnace Exhaust Venting Question bulls847 HVAC 1 01-30-2012 09:14 AM
venting through floor joist bignezzy74 HVAC 2 02-22-2011 07:52 AM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
