Old 12-05-2009, 01:43 PM   #1
etl
Exhaust Venting Materials
I've got a Rheem high efficiency furnace which has a leak. It’s where the pipe transitions from what looks like (black) ABS pipe which comes from inside the furnace to the PVC pipe which takes it out the roof. My guess is that with the different materials used the glue failed. I can’t cut out the problem area because its right at the furnace, I will need to replace the pipe that goes into the furnace. Is it safe to replace that pipe with PVC or does this section of pipe need to be a high temp plastic pipe? If does need to be something different than PVC what should the transition look like?
The furnace has the vent entering at the top which is where the main blower is located. This is the section of pipe that would need to be replaced. The burners are at the bottom and sectioned off from the top.
etl is offline   Reply With Quote
Old 12-05-2009, 04:34 PM   #2
The black plastic is a part of the furnace. I would contact the nearest Rheem supply house and get the correct part.
exhaust venting 7echo Roofing/Siding 2 07-23-2009 08:48 PM
Can I T my new dryer's exhaust into my bathrooms exhaust? Felipon Appliances 2 01-30-2008 07:53 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 03:52 PM
Furnace Exhaust To Outdoors celticFC HVAC 1 09-01-2007 02:27 PM
