Exhaust Through The Wall Or The Roof? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-30-2009, 03:23 PM   #1
Rewards Points: 83
Exhaust through the wall or the roof?
I plan on installing a unit heater with a 4" exhaust duct which will be exhausting some heat, along with the products of NG combustion. It is going to be installed in the garage, and I have the option of either going through the garage wall (wife thinks this will look ugly, but it would be much easier), or through the attic and out the roof (5" of snow presently).
Is there any advantages to one or the other? If I decided to exhaust through the wall, the vent would be very close to the soffit. Even if I meet minimum clearances, are there concerns with this carbon monoxide/smell/heat going into the attic.
thanks,
longshanks is offline   Reply With Quote
Old 11-30-2009, 06:04 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,122
Yep. Along with a LOT of water vapor which is really what most of the exhaust is made of. It will probably discolor the siding/soffit and get the wife mad at you. I would go vertical. If Momma ain't happy nobody is happy. (According to Dr.Phil).
Old 12-01-2009, 11:08 AM   #3
Rewards Points: 83
vertical it is.
thanks Yuri (and Dr. Phil)
6 in double wall through a metal roof johnnywalleye Roofing/Siding 11 11-27-2009 03:44 PM
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 07:06 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
