Exhaust Fan For Paint Spray Booth - HVAC - DIY Chatroom Home Improvement Forum
Old 05-19-2009, 01:17 PM   #1
Exhaust Fan for Paint Spray Booth
I am building a small 6' x 8' x 7' tall paint spray booth. It will have one open wall for air intake, and I need to add an exhaust fan on the other end. I plan to spray both water based and oil based finishes, and some will likely be flamable, but not overly explosive. I've looked at explosion proof fans, but the are cost prohibitive. I'm sure there must be some way to make a resonabley priced fan somewhat explosion proof. Can anyone help?
JEBNC2 is offline   Reply With Quote
Old 05-19-2009, 03:24 PM   #2
An old Tradesmen
Rewards Points: 6,540
You can't make a regular blower motor explosion proof.
You have to buy one that is made that way.
As much as they cost. They are far cheaper then you losing your insurance if you don't use one.
Old 05-19-2009, 06:09 PM   #3
Alternatives?
Then are there any alternatives to the "explosion proof" fans? Perhaps using one with a pulley drive and an external motor? How about a squarel cage type HVAC fan, where the motor is out of the airflow path?
Old 05-20-2009, 04:02 PM   #4
An old Tradesmen
I believe you still need explosion proof. As long as its in the room were if you don't turn the fan on right away. Fumes could build up.
Check your local building code. And or insurance company.
Old 05-23-2009, 07:38 AM   #5
biggles's Avatar
how about pressurizing the space and let the paint fumes go out thru louvered damper set up..you can put a potentiometer on the damper motor to control the pressure of the space with a supply fan running pumping the room up.the shafted fan to squirrel would definitly work and be safe that area the shaft connects the motor to the squirrel is always a negative during running so the motor is totally out of the paint electrical mix situation
Old 05-23-2009, 08:20 AM   #6
An old Tradesmen
The space probably wouldn't be air tight enough to only force the paint only out the opening.
Old 05-24-2009, 02:28 AM   #7
Rewards Points: 372
This project sounds like you need to check the codes in force in your area. If you are building a booth, will it meet fire code and building codes? the paint booths I have seen had hte motor outside of the exhaust air stream, but I never asked if the motor needed to be rated for hazardous use. If you run explosive/flammable vapors through the motor, expect some excitment. your electrical switches need to be a certain distance from openings. Your lights need to meet certain codes, If the booth is heated have you made provision for fuel shut-offs? If you are in an IFC state, you need a fire suppression system. If you do not meet local/state requirements, your insurance company may not cover any incidents.
fireguy is offline   Reply With Quote
Tags
booth , fan , paint , safety , spray
Spray foam insulation troyce1 Insulation 12 12-14-2014 07:30 AM
Special Spray for Roof Exhaust Vent's? amdspitfire Roofing/Siding 3 12-26-2008 11:46 AM
Can I T my new dryer's exhaust into my bathrooms exhaust? Felipon Appliances 2 01-30-2008 07:53 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 03:52 PM
Furnace Exhaust To Outdoors celticFC HVAC 1 09-01-2007 02:27 PM
