Exhaust Fan For Multiple Baths - HVAC - DIY Chatroom Home Improvement Forum
Old 05-04-2009, 03:12 PM   #1
Exhaust fan for multiple baths
I am remodeling an old 2 story house, and am installing 4 baths, 2 up and 2 down, 2 above the other 2. I want to install only 1 fan for all 4 baths, in the attic. Is this practical? If so, what size fan and motor should I look for? I'm thinking of venting it thru the roof, before I have the roof redone.
orbullock is offline   Reply With Quote
Old 05-04-2009, 03:50 PM   #2
"1.) First find the volume of the bathroom[s]. Volume = length x width x height
2.) Find the CFM (cubic feet per minute). Volume / 7.5
3.) This CFM is the minimum airflow required to achieve 8 air exchanges per hour.
Example: Volume = 10 x 6 x 8 = 480
CFM = 480/7.5 = 64
In this example you would only purchase a fan that has a CFM listed on the box greater than 64."
Ductwork/fitting losses may be significant for this application and if you really want to do it right you need the fan curve.
Old 05-04-2009, 05:26 PM   #3
An old Tradesmen
Rewards Points: 8,144
Min intermitant bathroom exhaust rate is 50CFM.
4 bathrooms, means you would need a fan capable of 200CFM.
Cost you more to reheat the fresh air, then you sane on fan cost.
Old 05-04-2009, 06:29 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 376
And you can depressurize the house/downdraft the chimney and get CO poisoning. Would need a make up air inlet and that wastes LOTS of energy $$. I removed my central fan and replaced it with an HRV.
Old 05-04-2009, 06:46 PM   #5
I guess you should price out all the options in view of the cautions. I s'pose you'd also need to balance the bathroom vents with dampers, just like a miniature HVAC duct system.
And buy a digital readout CO detector.
Old 05-04-2009, 06:54 PM   #6
Where are you located?
Arround here you don't want a lot of air being sucked out of the house in the winter
And in some areas the same is true in the summer - as you will be pulling in hot humid air
Old 05-04-2009, 07:48 PM   #7
Smile
Thanks a million for the input! It will probably more practical for me to put individual fans in each bath! I can make the vent pipes of the 2 downstairs baths to share an exterior exhaust vent through the outside wall, which is frame, with vinyl siding. The upstairs vents can go into the attic, and share an exhaust vent thru the roof.
Old 05-04-2009, 08:00 PM   #8
If they "share" a vent to the outside then it is possible for one bathrooms fan to push air into the other bathroom
Tags
4 to 1 bath vent fan , bath vent , multiple baths
Exhaust for Cooktop Mcrick HVAC 3 01-03-2009 06:51 AM
Central-vac exhaust curls00 General DIY Discussions 4 03-09-2008 12:28 PM
Can I T my new dryer's exhaust into my bathrooms exhaust? Felipon Appliances 2 01-30-2008 06:53 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 02:52 PM
Furnace Exhaust To Outdoors celticFC HVAC 1 09-01-2007 01:27 PM
