Old 10-19-2009, 01:08 AM   #1
vit
Default Exhaust fan / duct question
Hi!
I'm building a spraybooth with an exhaust fan for airbrushing.
I've got a booth made with exhaust at the back wall, with air plenum behind and a squirrel cage fan.
I have 2 setups in mind:
1) With a fan attached to the back of the booth/plenum and duct out of the window.
2) With fan mounted on the window with duct between booth/plenum and a fan.
The duct is a 3" diameter flexible duct. Exhaust opening on a fan is 1 1/4" X 2 1/8".
In which setup will I have more fan sucktion power loss?
Setup 2 is much easier for me to make at home...
Any help will be great! Thanks!
vit is offline   Reply With Quote
Old 10-19-2009, 02:38 AM   #2
Is the sprayed material flammable? Is this commercial usage?
Is the sprayed material going through the motor? Is the motor listed for flammable use? Make up air? What is the CFM of make-up and exhaust air? Is this a listed booth?
fireguy is offline   Reply With Quote
Old 10-19-2009, 12:22 PM   #3
vit
Is the sprayed material flammable? No
Is this commercial usage? No
Is the sprayed material going through the motor? No
Is the motor listed for flammable use? No
Make up air? ????
What is the CFM of make-up and exhaust air? No idea, the fan has no listing on it.
Is this a listed booth? No
So which setup do you think is better?
Old 10-19-2009, 01:22 PM   #4
Normally, the systems I work on are designed by an engineer, and we are given both exhaust and intake air requirements, duct sizes, and fan part numbers. And even then, we find problems in moving air.
You can purchase an annemomoter (sp?) which will measure air flow. Mine was less than $200.00 Or you can call a HVAC contractor to measure the air flow. One reason for intake air is to prevent expensive heated or cooled air from being blown outside. The air flow going out shoud be about 80 to 90 % of that brought in for intake air. I am going to assume this is a hobby type of booth, open face. The fan mounted on the wall will be the easiest to install. Is the exhaust duct a ridgid duct and not something like dryer duct? Dryer duct might collapse when the fan is on. And I am supposed to tell you to contact your local building department before any modifications are done.
Old 10-19-2009, 05:51 PM   #5
Yoyizit's Avatar
I think #1 will work better because the area of intake is supposed to be 4x the swept area of the blades, but this library book
http://www.amazon.com/Mechanical-Eng...5985475&sr=8-4
is more credible than I am.
More On This Topic
A short ram intake is a very simple version of a cold air intake system, which reduces the air temperature inside an internal combustion engine. A short ram intake system usually consists of a short metal pipe and an air filter, which combine to increase... Read More »
Creating delicious meals for the family at home also creates tantalizing aromas in the air. However, you need proper air ventilation to remove odors from grease, smoke and moisture. Whether you're redoing your kitchen or building a new home, several... Read More »
The kitchen is usually the hottest room in a home. Due to the heat generated by stovetops, ovens and toasters, most kitchens are equipped with exhaust fans. These small, but powerful, fans are usually located inside a hood just above a stovetop. Hot air... Read More »
A clothes dryer doesn't need a lot of maintenance, but what it does need is important if you don't want to come home to a load of burnt laundry--or a burnt house. Following are steps for making sure to maintain your clothes dryer, keeping it free of lint... Read More »
question on return duct familyman HVAC 13 01-25-2009 01:05 PM
Return duct "boot or no boot" ads67 HVAC 16 01-10-2009 11:38 AM
Furnace install in attic - Duct configuration hartkem HVAC 6 11-08-2008 07:46 PM
Can I T my new dryer's exhaust into my bathrooms exhaust? Felipon Appliances 2 01-30-2008 08:53 PM
Duct Work Question xlr8tn HVAC 1 01-19-2008 11:02 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
